Dirty oil in the plastic elbow - Mercedes-Benz Forum
LinkBack Thread Tools
Old 06-17-2019, 01:47 PM Thread Starter
Date registered: Jun 2019
Vehicle: 2006 C230S
After cleaning the MAF sensor on my M272 I was going to spray out the throttle body as well. And found a lot of oil and dirt in the plastic diverter that fits between the MAF and TB. When I say dirt I mean the kind you can roll between your fingers and it and the oil appears to be coming from the hose that connects that part to the engine.
I would think that maybe the car has been ran with that hose unattached for awhile if it would run in that configuration, however the hose was well attached when I started the project.
Any thoughts on how it could get that way and how to fix the problem would be appreciated.
Marilyn2006 is offline
Old 06-17-2019, 08:13 PM
Benzyle's Avatar
Date registered: Nov 2013
Vehicle: MY05 CLK55 AMG , MY05 CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
Quoted: 299 Post(s)
This could be related to the centrifugal oil separator which is located on the back end of the right cylinder head.
This is part of your positive crankcase ventilation system.
Check that all hoses are well connected ,,,or if you want to you could remove the separator and check it out /clean it etc ,,but I have no exact knowledge on how they work.
Marilyn2006 likes this.
Benzyle is offline
Old 06-17-2019, 08:39 PM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1694 Post(s)
The purpose of the centrifuge (a modern version of the PCV valve) is to let air vent from the crankcase without bringing oil with it. Even when everything is working properly, there will still be some oil suspended in the air that makes its way into that hose, the elbow, the throttle body and manifold. A good cleaning of all of this never hurts.
- RODNEY
My Stable:
rudeney is online now
Old 06-18-2019, 05:15 AM Thread Starter
Vehicle: 2006 C230S
Thank you, very informative. My main concern now is the grit in the oil, which would have to be from wearing engine components, because I saw no evidence that the air-filter was allowing dirt through. The MAFS and path before the diverter was clean. Is it possible that the oil separator is disintegrating?
Old 06-18-2019, 07:58 PM
rudeney's Avatar
I doubt it. The grit is probably just the result of very tiny dirt molecules that collect in the "sludge" oil in the tube. It's normal.
noetico likes this.
- RODNEY
My Stable:
Old 06-19-2019, 08:21 AM Thread Starter
Vehicle: 2006 C230S
Good to hear. it's cleaned up now. Hopefully the oil held onto all the contaminates and we'll be good for another ten years. By then everything will be powered by batteries anyway.
