06 C280 P0016 P0017 - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 06-13-2019, 07:31 PM Thread Starter
Date registered: Jun 2019
06 C280 P0016 P0017
Hi all, new here and just purchased my first Mercedes. I bought it from a dealership and the sales person ensured me the CEL was nothing to be concerned about but was unable to provide a DTC printout due to them not doing an "official" inspection on it. The codes thrown are P0016 and P0017, crank/cam correlation bank 1 sensors A & B. As someone who was once a mechanic, this sounds like a cam gear/balancer issue to me. Any known problems I should look for first, and any tricks for diagnosing these?
Thanks!
Jubbsta is offline
post #2 of 15 (permalink) Old 06-13-2019, 07:40 PM Thread Starter
Edit: after doing some searching it would seem a faulty balancer shaft is common on these motors. I figure it's better to replace it before I skip a tooth. Does anybody have access to the repair procedures?
Jubbsta is offline
post #3 of 15 (permalink) Old 06-13-2019, 08:47 PM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1692 Post(s)
Actually, it won't skip a tooth, but it could eventually damage the timing chain. This is an engine-out job. I think I have all the WIS docs here:
http://benzbits.com/M272/ReplaceBalanceShaft.zip
- RODNEY
My Stable:
rudeney is offline
post #4 of 15 (permalink) Old 06-13-2019, 08:52 PM Thread Starter
Thank you very much! Ill post updates as they come along
Jubbsta is offline
post #5 of 15 (permalink) Old 06-13-2019, 10:59 PM
tjts1's Avatar
Date registered: Apr 2009
Vehicle: 87 300D 5 speed
Quoted: 691 Post(s)
Thanks!
What state are you in? Most states have a grace period where you can return a used car to a dealer for a full refund.
Triggering religious fanatics since 1969
tjts1 is offline
post #6 of 15 (permalink) Old 06-13-2019, 11:41 PM Thread Starter
Tjts1, I'm located in Michigan, I'm unable to return the vehicle due to it being sold "as is".. my salesperson told me there is nothing he can do. I've owned it for only 2 days now.
Jubbsta is offline
post #7 of 15 (permalink) Old 06-14-2019, 03:32 AM
Date registered: Jan 2019
https://www.autoguysland.com/best-car-diagnostic-tool/
Thanks!
Hi.
Do you have any engine running issues?
Have you tried deleting the codes to see how long it will take for them to come back?
In addition to balancer, there are few other possibilities:
- stretched chain
- weak tensioner
- failing craknshaft sensor.
Hope that helps.
harveyspecter1209 is offline
post #8 of 15 (permalink) Old 06-14-2019, 07:09 AM
tjts1's Avatar
Quoted: 691 Post(s)
Unfortunately situations like yours pop up on this forum regularly, usually with 06 and early 07 cars. As previously mentioned it's an engine out repair that will likely cost as much as the car is worth. NEVER buy a car with a check engine light, always do your homework before buying and get a PPI.
tjts1 is offline
post #9 of 15 (permalink) Old 06-14-2019, 10:24 AM Thread Starter
Thanks!
Hi.
- stretched chain
- weak tensioner
Hope that helps.
Yesterday I cleared the codes and changed the oil, after the oil change i lrt it idle for 5-10 minutes, no CEL, then as soon ss i cranked it the next time CEL came on.. Very very lightly rough idle SOMETIMES, I found the inlet for the air pump was disconnected, after reconnecting it, seems to rub fine..
Jubbsta is offline
post #10 of 15 (permalink) Old 06-14-2019, 10:27 AM Thread Starter
General ball park for the price of parts if i do it the proper way? I.E oil pump, chain n guides, the whole works..? Im going to pull the 4 pulse magnets and check the stampings on the cam gears, and maybe put a boroscope down to see if there's any damage to the walls from metal shavings..
Jubbsta is offline
