03 C230K coupe: This darn 722.6 transmission - Mercedes-Benz Forum
post #1 of 31 (permalink) Old 05-26-2019, 07:59 AM Thread Starter
Date registered: Nov 2012
Vehicle: 2003 Mercedes Benz c230 coupe with automatic and evolution package
Quoted: 10 Post(s)
So, the transmission saga continues.
I was running up until lately (not the best, with hard shifts from 2 to 3rd gear) but now when you shift in drive it won't engage the gear, the engine just rev's. But if i turn the car off for a minute then restart the gear engages??? Opened the floor shifter and spayed with contact cleaner. Opened the TCM under the glove box and sprayed with cleaner...NOTHING...I towed it to a reputable MB independent here in Toronto, he placed it on his super duper OBD reader computer and he says the transmission needs rebuilding. $2500 bucks...Gears are slipping. Conductor plate pulls no code only a generic gear implausible/gear slipping code p25XX??
WTF can it be? This seems more electronic then mechanical to me...Any thoughts??? Can it be the transmission oil pump? When I'm lucky to get it in drive mode there is a more than usual whining sound from the trans. Then i come to a stop sign, it falls back to first gear and then the problem happens, It won't engage the gear, i shut off the car, wait a minute, restart and then it drives until i stop again...When gear is not engaged and you rev, there is no whining sound....I'm ready to take a sledge hammer to this thing :-)
help
jamiec230 is offline
post #2 of 31 (permalink) Old 05-26-2019, 08:21 AM
tjts1's Avatar
Date registered: Apr 2009
Vehicle: 87 300D 5 speed
Quoted: 690 Post(s)
I was running up until lately (not the best, with hard shifts from 2 to 3rd gear) but now when you shift in drive it won't engage the gear, the engine just rev's. But if i turn the car off for a minute then restart the gear engages??? Opened the floor shifter and spayed with contact cleaner. Opened the TCM under the glove box and sprayed with cleaner...NOTHING...I towed it to a reputable MB independent here in Toronto, he placed it on his super duper OBD reader computer and he says the transmission needs rebuilding. $2500 bucks...Gears are slipping. Conductor plate pulls no code only a generic gear implausible/gear shifting code p25XX??
WTF can it be? This seems more electronic then mechanical to me...Any thoughts??? Can it be the transmission oil pump? When in drive mode there is a more than usual whining sound from the trans. When gear is not engaged and you rev, there is no whining sound....I'm ready to take a sledge hammer to this thing 🙂
help
Find a different mechanic. It needs a conductor plate.
Benzyle likes this.
Triggering religious fanatics since 1969
tjts1 is online now
post #3 of 31 (permalink) Old 05-26-2019, 05:57 PM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1678 Post(s)
Have you checked the fluid level?
Benzyle likes this.
- RODNEY
My Stable:
rudeney is offline
post #4 of 31 (permalink) Old 05-31-2019, 12:22 PM Thread Starter
Quoted: 10 Post(s)
Rudeney,
Your right, I bought the dip stick, it's low on fluid. Where did it go? I see no physical leaks on floor...
Do i specifically need the MB trans oil or can I use a Valvoline MAX LIFE ATF Dex/Merc' Mercon LV?
Also what are your thoughts on topping it up with LUCAS transmission fix?
thx jamie
post #5 of 31 (permalink) Old 05-31-2019, 07:25 PM
rudeney's Avatar
Check around the electrical connector on the transmission - it's a common place for leaks.
These are the approved fluids:
https://bevo.mercedes-benz.com/bevol...236.14_en.html
I would not us anything not on that list.
- RODNEY
My Stable:
rudeney is offline
post #6 of 31 (permalink) Old 05-31-2019, 09:48 PM
tjts1's Avatar
Quoted: 690 Post(s)
The list is wrong.
tjts1 is online now
post #7 of 31 (permalink) Old 06-01-2019, 05:58 AM
rudeney's Avatar
Originally Posted by tjts1 View Post
The list is wrong.
Why do you say that?
- RODNEY
My Stable:
rudeney is offline
post #8 of 31 (permalink) Old 06-01-2019, 10:43 AM Thread Starter
Quoted: 10 Post(s)
Thanks Rudeney,
They have the Fuchs Titan 4134 compatible oil from your list through Amazon.ca for $21 cnd 1lt or Germanparts.ca $13 cnd 1lt
https://www.amazon.ca/Mercedes-Trans...gateway&sr=8-2
I will add some and see what happens,
thx again
Jamie :-)
post #9 of 31 (permalink) Old 06-01-2019, 05:25 PM
rudeney's Avatar
Just make sure you put it in the correct tube:
- RODNEY
My Stable:
rudeney is offline
post #10 of 31 (permalink) Old 06-08-2019, 10:14 AM
Date registered: Jun 2019
Quoted: 5 Post(s)
I'm having issues with my spcoupe 2002.
Bought it a few months ago , and notice the car went in limp mode from time to time, had to pull over, kill the ignition, wait few seconds, restart engine, all fine...
Had the car diagnosed, don't know error codes, but he told me i have to replace electronic plate on transmission, and also told the problem would agravate, wich it did.
I'm working in France and had no time to adress the problem back then, so kept driving hoping it would hold till august , when i'd return and fix it.
Well at the moment i'm stuck in limp, already ordered parts, filter, joint, plate, atf, etc...
Today i read about atf climbing through the wires, took a look at the TCM, and though there ARE signs of oil in the wires and conector (left), i removed TCM , opened it gently, and inside is clean and dry, which leads me to believe either the leak is not very big and o-rings on the plate conector aren't that bad, or maybe the problem was adressed in the past...
The clip in the cap where you put in the oil is also broken...
Is there a cheap diagnostic tool, that is able to erase error codes after intervention?
The transm is a 722.699, the car shows 280k.
Thank you all in advance!
Sportcoupe2002 is offline
