C320 Engine compatabilty - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 05-20-2019, 01:32 PM Thread Starter
Steven_Renich's Avatar
Date registered: Apr 2019
Vehicle: 2004 C320 4Matic
Quoted: 4 Post(s)
I have a 2004 C320 4matic and am considering an engine replacement. This would be from a working vehicle with the same engine (3.2l V6, 4matic) but possibly different year or body style. I would use the accessories from my engine.
In general, are there any snags I should look out for?
Where could I find out if the engine from car "A" would fit in my car?
Thanks.
Steven_Renich is offline
post #2 of 7 (permalink) Old 05-20-2019, 07:34 PM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1665 Post(s)
So you are replacing both the engine and transmission? These are specific to the C320 4MATIC. My advice is to find another C320 4MATIC from a crash with severe body damage, but a good drivetrain.
- RODNEY
My Stable:
rudeney is offline
post #3 of 7 (permalink) Old 05-20-2019, 10:18 PM
tjts1's Avatar
Date registered: Apr 2009
Vehicle: 87 300D 5 speed
Quoted: 689 Post(s)
Thanks.
Get a 3.7 from an ML350.
Triggering religious fanatics since 1969
tjts1 is offline
post #4 of 7 (permalink) Old 05-21-2019, 08:17 AM Thread Starter
Quoted: 4 Post(s)
A little explanation...
Rodney,
Yes I am thinking of replacing both engine and transmission. The trans needs to be fixed now and the 190k motor runs fine, but is very noisy and uses oil. At this point I not sure I want to fix the trans without knowing I can take care of the engine if it goes in a year. So I am looking at driveable wrecks with relatively low mileage. If I go this route, I would buy the car and install the trans now, and keep the engine to install later. This option costs a bit less than a low mileage trans shipped from some full service junkyard.
Steven
post #5 of 7 (permalink) Old 05-21-2019, 09:38 AM Thread Starter
Quoted: 4 Post(s)
Question More questions
First, thank you for the advice. However, I am still not understanding these engines.
tjts1,
Do we know if the 3.7l has the same motor mounts, machining for AC brakets, and a thousand other things that bolt onto the engine?
Even if all the accessories move over, wouldn't I need to reprogram the ECU with an SDS?
Have you done such a swap, or do you know if if can be done?
Rodney,
What about this combination is specific to the C320 4matic?
I understand that an E320 RWD might have a different ECU and cam for example, and that the emissions equipment on a 2004 would be different from a 1998 3.2l. But even so, shouldn't I be able to bolt the 1998 3.2l engine into the 2004 car?
Thanks,
Steven
post #6 of 7 (permalink) Old 05-21-2019, 10:45 AM
tjts1's Avatar
Quoted: 689 Post(s)
tjts1,
Steven
The 3.7 is externally the same to your 3.2. you will have to swap over your oil pan, engine mount arms and accessories. All the hardpoints on the engine are identical. Your existing ECU will adopt the extra displacement. For all intents and purposes it's the exact same m112 engine with a larger cylinder bore.
Thanks,
Steven
MB made some improvements on the M112 in 2002 and again in 04. Larger oil galleries, better castings. I would get the newest engine possible. Yes a 98 engine will drop right in and work but I wouldn't choose that route.
tjts1 is offline
post #7 of 7 (permalink) Old 05-21-2019, 11:06 AM
tabijan's Avatar
Date registered: Jan 2017
Vehicle: 1998 E320s sedan and wagon
Quoted: 216 Post(s)
It concerns me that you haven’t referred to the engine by it’s M112 designation as tjts1 did. Since you have a core engine, anything you need to make another 3.2 M112 work is at hand. I don’t know what it takes to swap an M112 of a different displacement.
With prices of these cars dropping, I wonder if your plan is cost effective. Or have I said that already?
Sixto
98 E320 wagon
02 C320 wagon
tabijan is offline
2007 S550 W221 Motor Mount Replacement PWidge W221 S-Class 12 12-30-2018 04:48 PM
Injection Pump fuel adjustment for the MW and M pumps, engine tuning and maintenance Forcedinduction W123 E,CE,D,CD,TD,TE Class 5 11-28-2017 01:19 AM
Removing the engine on a 500SL, step by step hchaugli R/C107 SL/SLC Class 42 01-12-2017 02:15 PM
My 190E hath descended into Mechanic's Hell! 85BabyBenz W201 190-Class 38 11-05-2014 07:05 PM
Fan keeps running bossjj98 W163 M-Class 311 08-14-2014 05:42 PM
