Some sort if valve - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 05-20-2019, 06:06 AM Thread Starter
Date registered: May 2019
Vehicle: Merc, C270 CDI, 2002, Auto
Some sort if valve
Hi, I am new to this forum and new to the Benz world.
I purchased a W203 C270 CDi
I have to replace the thermostat recently. I have also noticed a rattle coming from an area just sitting behind the oil filter to the left. Assuming, the previous owner or mechanic dropped something down into this area. was having a feel around to see if I can remove the foreign object. I couldn't feel anything loose except for some sort of valve. It was protruding down and loose. You could push it back up but it would come down straight away.
Am i right in thinking this is the Swirl Flap valve? If so is this supposed to be connected to some sort of rod control?
I couldn't get any pictures due to the tight space. If anyone can supply me with some images of this section and how it supposed to look and work, it would be greatly appreciated.
Thanks.
Robert Rafferty is offline
post #2 of 6 (permalink) Old 05-20-2019, 09:53 AM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1692 Post(s)
Hi Robert - welcome to the forum! Please take a moment to visit the User Control Panel and update your profile to include your car model and year, and your location (at least country). This information will then appear below your name and avatar on the left side panel next to each post you make. This will greatly help others to give you better information. If you are using the mobile version of the site, you will need to switch to the "full" version to get to the User Control Panel.
I'm sorry I can;t help there - we did not get those C270's here int he USA.
- RODNEY
My Stable:
rudeney is offline
post #3 of 6 (permalink) Old 05-22-2019, 01:09 AM Thread Starter
All done thank you
post #4 of 6 (permalink) Old 06-04-2019, 07:32 AM
Date registered: Dec 2003
Vehicle: MB 180 W120(1962) MB C200 W203(2007)
Could you tell us exactly what you did? Others may benefit from it in future, That is the whole purpose of this forum. We share our experiences.
rudeney likes this.
Shan is offline
post #5 of 6 (permalink) Old 06-10-2019, 06:08 AM Thread Starter
Hi, sorry for the late reply when i said " all done!" i meant updating my profile.
In regards to the Valve i have found out it is the linage to the swirl flap coming loose from the linkage. My guess the intake mani is going to have to come off. Swirl flap delete or repair ;s its the closest one to the front of the car. just the one i think. can any one tell me how this will effect the drive ? boost leak ?
post #6 of 6 (permalink) Old 06-10-2019, 07:27 AM
rudeney's Avatar
There are two things going on inside the intake manifold. There are "swirl flaps", and there are "runners". The swirl flaps are engaged at lower engine speeds to create more turbulence which generates a more consistent air/fuel mixture. At higher RPMs, since the incoming air is turbulent enough, the flaps are opened fully. The "runners" are used to vary the length of the intake manifold path. At higher speeds, a shorter length is desired for better efficiency. At lower speed, a longer length is better for improving low-end torque.
I think that when either the swirl flap or runner actuators or linkages fail, they are locked into the "high RPM" position. This means the engine will perform as normal at higher speeds, but will not have as much torque at lower speeds/take-off.
- RODNEY
My Stable:
rudeney is offline
Do It Yourself (DIY) repair thread and wheel and tyre thread Dr.Grillz W126 S,SE,SEC,SEL,SD,SDL Class 250 Yesterday 06:11 AM
Understanding cold start DG91500SL R129 SL-Class 37 03-02-2019 01:59 PM
AC Controller, Duo Valve Heater Core / AC Conflicts - Resolved ramblinche81 W140 S-Class 7 04-15-2016 03:36 AM
Remote control of hydraulic circuits in 416 cab? aaronsb Unimog 24 11-02-2013 11:08 AM
Discount Tire: Recall valve stems supplied by Dill Air Controls (Dill) Kirill R170 SLK-Class 2 09-12-2008 06:15 AM
