C200 kompressor - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-11-2019, 10:31 AM Thread Starter
Date registered: May 2019
C200 kompressor
Hello colleagues I have a problem with the car that I can not solve for a very long time, it's about cold start The engine has an rough iddle and unstable run for 1 minute After returning to, the star diagnostic I have no error had, i chek the vaccum spark plugs, egr, throtle body, maf, map... this problem the car in question is c200 kompressor2002 M111. 955 120 kw
ovineagu23 is offline
post #2 of 2 (permalink) Old 05-12-2019, 07:13 PM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1629 Post(s)
Welcome to the forum! Please take a moment to visit the User Control Panel and update your profile to include your car model and year, and your location (at least country). This information will then appear below your name and avatar on the left side panel next to each post you make. This will greatly help others to give you better information. If you are using the mobile version of the site, you will need to switch to the "full" version to get to the User Control Panel.
So this is only when it's cold? And when it warms up it runs fine? Is it getting a valid engine/coolant temperature reading?
- RODNEY
My Stable:
rudeney is offline
Help Needed to find OEM A/C Compressor for 08 C200 Kompressor sirstig W204 C-Class 9 07-04-2016 01:19 AM
Which C200 Kompressor - 2007 or 2008 Build? Bodog W204 C-Class 2 03-14-2011 03:21 AM
'97 C200 Kompressor 97c200K W202 C-Class 1 01-30-2010 10:00 AM
K&N Filter 33-2703 New Price: $48.37 dlbehrns C208/A208 CLK-Class 0 08-07-2009 08:21 PM
M271 C200 Kompressor vs V6 C240 VBlaster W203 C-Class 4 11-07-2004 07:30 AM
