Bent valves - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 05-10-2019, 09:28 PM Thread Starter
Date registered: Jan 2019
Vehicle: 2005 C230 Kompressor Sport
Quoted: 7 Post(s)
Bent valves
Just did my timing chain. Car idles and shakes violently, is this due to bent valves?
Kperinuzzi is offline
post #2 of 16 (permalink) Old 05-10-2019, 09:30 PM
Date registered: Mar 2019
Vehicle: 1998 E300 turbo diesel
Quoted: 12 Post(s)
Why did you do a timing chain to begin with? Maintenance?
Mr Krabs is offline
post #3 of 16 (permalink) Old 05-10-2019, 09:38 PM Thread Starter
Quoted: 7 Post(s)
No, chain jumped time. At cold start it sounded horrible, rough, and shaking violently. Chain was stretched badly, right camshaft gear teeth where worn all
The way down.
post #4 of 16 (permalink) Old 05-11-2019, 02:24 AM
Date registered: Mar 2004
Vehicle: Amethyst 2001 C320
Quoted: 5 Post(s)
The way down.
Did you replace the camshaft gear? Did you replace the timing chain tensioner? And are you 100% sure you have the timing aligned correctly?
Is the check engine light on? What codes is it throwing?
Benzyle likes this.
n0alpha is offline
post #5 of 16 (permalink) Old 05-11-2019, 03:20 AM
Benzyle's Avatar
Date registered: Nov 2013
Vehicle: MY05 CLK55 AMG , MY05 CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
Quoted: 297 Post(s)
Check valve timing ,,,Better to turn the engine using the crankshaft pulley bolt,,,turn in a clockwise direction only.
Benzyle is offline
post #6 of 16 (permalink) Old 05-12-2019, 05:50 PM Thread Starter
Quoted: 7 Post(s)
I did not change the tensioner. When I press on the left orange plastic holding the chain I hear it, it’s keeping the new chain very tight. I feel I do not have to replace it. I have been turning the engine over using the left camshaft gear I have not been turning over by the pulley. When I move the engine over by the left camshaft gear the right one and pulley all move. Do I have to crank the engine by the pulley? It is throwing many codes as it did before, miss firing in all 4 cylinders. Engine sounds the same as it was before, shakes violently as if something is hitting inside.
post #7 of 16 (permalink) Old 05-12-2019, 05:56 PM Thread Starter
Quoted: 7 Post(s)
I lined up everything and riveted the chain, when the 0IT was lined up I put a screw driver in piston one hole n piston is to the top however the left n camshaft gear don’t fit in the slot comfortably there’s off from the markings, I had to wrench both to the marking n put the chain in to hold camshafts in place so they line up correctly. Idk what to do from here on out I’m frazzled
ID:	2512142   Click image for larger version
ID:	2512144   Click image for larger version
ID:	2512146   Click image for larger version
post #8 of 16 (permalink) Old 05-14-2019, 05:29 AM
Benzyle's Avatar
Quoted: 297 Post(s)
Turn the engine over many times using a socket on the bolt of the crankshaft,,,turn clockwise only..
Check that all timing marks on camshafts and crankshaft line up correctly.
Benzyle is offline
post #9 of 16 (permalink) Old 05-14-2019, 05:53 AM Thread Starter
Quoted: 7 Post(s)
Hey Benzyle,
Isn't turning the crank pulley the same as turning the camshaft gear to get everything moving? I have the belt on as well.
post #10 of 16 (permalink) Old 05-14-2019, 07:23 AM Thread Starter
Quoted: 7 Post(s)
What should be my next move?
The timing is lined up accurately. When I started the car it sounds like something is hitting, would this be bent valves? Can someone verify this please? I have taken the chain off and on 2 times already and the car is not running right. PLEASE HELP!
SBC Brake Flush Revisited (Again) - In Great Detail smyers The Discount Tire Direct Tire, Wheel, Brake & Suspension 8 05-11-2019 02:17 PM
DIY Brakes, with pictures... Check Codes W210 E-Class 155 02-25-2019 03:22 PM
1999 ML 320 Seconday Air Injection Valves uss1814 General Mercedes-Benz 0 02-12-2012 07:30 AM
Timing Chain Rail 'Cylindrical Pin' Bent rlippincott W126 S,SE,SEC,SEL,SD,SDL Class 1 12-07-2011 01:26 PM
Exhaust valves burnt miked56 R/C107 SL/SLC Class 4 12-18-2007 06:39 AM
