Bent valves - Page 2 - Mercedes-Benz Forum
post #11 of 18 (permalink) Old 05-14-2019, 07:31 AM Thread Starter
Date registered: Jan 2019
Vehicle: 2005 C230 Kompressor Sport
Quoted: 8 Post(s)
Please Help
I forgot to mention, when i have the pulley at 0IT when I put the camshaft gears on top the left camshaft gear doesn't fit in properly at the begging or line up accurately. I had to get a wrench and wrench towards the right to line it up then drill the top cover to keep it in place. I started car and it sounded horrible (rough Idle). So I took the engine apart again, and with a wrench turned the left camshaft over so the right camshaft and pulley moved along as well to get the pistons moving. everything turns over and is lined up...Odd. I did notice at one point of turning the engine is more difficult to turn over. What am I doing wrong?
Kperinuzzi is offline
post #12 of 18 (permalink) Old 05-14-2019, 11:08 AM
tabijan's Avatar
Date registered: Jan 2017
Vehicle: 1998 E320s sedan and wagon
Quoted: 216 Post(s)
Maybe oil isnít getting to the lifters.
A compression test might be your next step.
Sixto
98 E320 wagon
02 C320 wagon
tabijan is offline
post #13 of 18 (permalink) Old 05-14-2019, 12:03 PM Thread Starter
Quoted: 8 Post(s)
Car runs like this but the engine shakes violently.
post #14 of 18 (permalink) Old 05-14-2019, 03:26 PM
Benzyle's Avatar
Date registered: Nov 2013
Vehicle: MY05 CLK55 AMG , MY05 CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
Quoted: 306 Post(s)
Originally Posted by Kperinuzzi View Post
Hey Benzyle,
Isn't turning the crank pulley the same as turning the camshaft gear to get everything moving? I have the belt on as well.
I don't know for certain ,,but when I have a problem I try to do everything the right way...
Rotate the engine using the crankshaft and confirm that 0 T corresponds to the number one piston being at the top of its compression stroke.
Then check camshaft timing marks are also correct.
Benzyle is offline
post #15 of 18 (permalink) Old 05-14-2019, 04:28 PM
tabijan's Avatar
Quoted: 216 Post(s)
Is the chain tensioner in good shape? Installed properly?
Sixto
98 E320 wagon
02 C320 wagon
tabijan is offline
post #16 of 18 (permalink) Old 05-14-2019, 06:03 PM
Date registered: Mar 2019
Vehicle: 1998 E300 turbo diesel
Quoted: 14 Post(s)
you need to do yourself a favor and do a leak down test. compression test if you dont have a leak down tester. post results. harbor freight has both for cheap.
Mr Krabs is offline
post #17 of 18 (permalink) Old 08-13-2019, 09:21 AM
Vehicle: 2005 C230 and 1998 SLK230
230 Kompressor timing
Originally Posted by Benzyle View Post
Turn the engine over many times using a socket on the bolt of the crankshaft,,,turn clockwise only..
Check that all timing marks on camshafts and crankshaft line up correctly.
Just to confirm what you are saying.... With TD center on the harmonic balancer and both cam adjusters lined up. Turn the crankshaft clockwise and when it comes back around they should all line up again....every time around??
I had a guy tell me that they would only line up every 2 times around. That didnt sound right nor did it sound possible to me.
I have mine put back together except for plugs and coil packs, I would like to check it like this first before trying to crank it.... This is my first timing chain replacement
johnsonstephen31029 is offline
post #18 of 18 (permalink) Old 08-13-2019, 04:12 PM
Benzyle's Avatar
Quoted: 306 Post(s)
The M271 1.8 kompressor is a DOHC 4 stroke engine.. intake ,compression ,combustion exhaust.
The crank rotates twice and each cam rotates once per cycle.
So that means they will line up every 720 degrees.
After number one has been put at TDC on compression stroke ,,rotating 180 degrees will put cylinder 3 at TDC. compression. 180 more will put cylinder 4 at compression tdc ,,,and then 180 more will put cylinder 2 at compression tdc.
Good luck.
Benzyle is offline
SBC Brake Flush Revisited (Again) - In Great Detail smyers The Discount Tire Direct Tire, Wheel, Brake & Suspension 8 05-11-2019 02:17 PM
DIY Brakes, with pictures... Check Codes W210 E-Class 155 02-25-2019 03:22 PM
1999 ML 320 Seconday Air Injection Valves uss1814 General Mercedes-Benz 0 02-12-2012 07:30 AM
Timing Chain Rail 'Cylindrical Pin' Bent rlippincott W126 S,SE,SEC,SEL,SD,SDL Class 1 12-07-2011 01:26 PM
Exhaust valves burnt miked56 R/C107 SL/SLC Class 4 12-18-2007 06:39 AM
