Question about sports suspension - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 05-03-2019, 06:38 PM Thread Starter
Date registered: Dec 2018
I want to ask about upgrading to sport suspension.Currenlty i have the classic variant and a i am planning to get the Sachs shocks with code for the sport susp.Do i have to upgrade the springs as well because EPC says that more than one type of springs is compatible with the sport shocks?
sale100 is offline
post #2 of 6 (permalink) Old 05-03-2019, 09:17 PM
Benzyle's Avatar
Date registered: Nov 2013
Vehicle: MY05 CLK55 AMG , MY05 CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
Quoted: 297 Post(s)
be aware that sport suspension cars also have larger stabiliser bars with larger links and bushings with larger diameter bolts which attach to the strut.
Benzyle is offline
post #3 of 6 (permalink) Old 05-03-2019, 09:36 PM
tjts1's Avatar
Date registered: Apr 2009
Vehicle: 87 300D 5 speed
Quoted: 691 Post(s)
Yes you have to swap the springs and sway bar end links too at the same time.
Triggering religious fanatics since 1969
tjts1 is online now
post #4 of 6 (permalink) Old 05-04-2019, 07:49 AM
tabijan's Avatar
Date registered: Jan 2017
Vehicle: 1998 E320s sedan and wagon
Quoted: 216 Post(s)
Do you have to do the springs at the same time as the shocks?
Sixto
98 E320 wagon
02 C320 wagon
tabijan is offline
post #5 of 6 (permalink) Old 05-04-2019, 08:19 AM
tjts1's Avatar
Quoted: 691 Post(s)
Sixto
98 E320 wagon
02 C320 wagon
In the front yes. Both the spring and strut are 1.5" shorter.
On the rear of the wagon you just need to change the shock. The rear springs are the same PN as the clk55. C55 or CLK55 sway bars are also nice.
tjts1 is online now
post #6 of 6 (permalink) Old 05-31-2019, 10:07 PM
begbpc's Avatar
Date registered: Sep 2008
Vehicle: 2005 C230 Kompressor
I have an 2005 c230 kompressor and have some worn components. Is there a reasonable kit to check out? Going to replace control arms thought I might do a front drop too.
begbpc is offline
Shooting gallery p100 Off-Topic 13436 06-27-2019 02:43 PM
Arnott Updates Lineup of Aftermarket Air Suspension Parts for Mercedes-Benz Owners ArnottDoug The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 08-29-2014 12:13 PM
Short Q: W203 FL Sports Suspension to Normal? bbwannabe W203 C-Class 7 05-26-2009 10:58 AM
New here - Suspension Question Daniele R170 SLK-Class 27 09-28-2006 10:24 PM
Sports suspension option for CLK550 dan212 C209/A209 CLK-Class 10 09-18-2006 04:49 AM
