2002 c240 - No fuel pressure - Page 2 - Mercedes-Benz Forum
post #11 of 11 (permalink) Old 04-30-2019, 08:57 PM
Date registered: Mar 2004
Vehicle: Amethyst 2001 C320
Quoted: 5 Post(s)
Originally Posted by Joshua Preciado View Post
Thank you. Now I'm starting to think that might be it too. Cuz now I've replaced the fuel filter, fuel pump and about 3 days ago I replaced the Crank Position Sensor... And still doing the same thing. Engine is turning over and turning over, but no start and no fuel pressure to the engine... Ugghhhh .
Sorry to hear that. At this point it comes back to the basics of troubleshooting step by step. Obviously, always use appropriate care when working with the fuel system.
Electrical Tests
1. What is the voltage at the car battery?
2. What is the voltage at the fuel pump fuse?
3. Is the fuse good? (Ohm resistance test). Can you replace it with a new one to be sure?
4. Is the fuel pump relay good? Can you replace it with a new one to be sure?
5. What is the voltage at the wire harness that connects to the fuel pump when the key is turned to the run position?
Mechanical Tests
1. How much fuel is in the tank?
2. What is the PSI on the fuel rail? (is it 0, or something greater than 0 but less than 60?)
3. Do both sides of the tank have equal fuel level?
4. Does the fuel pump make noise when the car ignition is put into the run position?
5. Does the fuel pump pump fuel with the sending unit disconnected? (you can connect a piece of tubing on the output of the pump and into a gas can for safety)
6. Is the sending unit in the driver's side of the tank clogged/broken? (If yes, the car won't run below 1/2 tank of fuel on the fuel gauge)
7. Is the fuel filter clogged? (The pressure regulator is part of the filter and could be faulty)
8. Are the fuel lines from the pump to the fuel rail clogged?
9. Is the fuel rail faulty? (You can check the fuel line that connects to the rail to see if fuel comes out when the key is in the run position)
10. Are any of the fuel injectors faulty? Theoretically a bad fuel injector that is dumping fuel wide open into a cylinder could cause a low pressure condition on the fuel rail schrader valve - a reading of 0 PSI is unlikely in this case.
Depending on the answers to the above, we can help narrow it down for you.
Regards,
n0alpha
n0alpha is offline
Primer on diesel injection- How it works, general troubleshooting, and maintenance Rossafuss W211 E-Class 11 11-15-2017 08:11 AM
Shots fired Smackrattle Off-Topic 118 03-25-2017 09:51 PM
Fuel System Service BenzHacker R/C107 SL/SLC Class 14 01-17-2016 07:24 AM
W140 Fix it Yourself Articles Merc600sec W140 S-Class 265 11-04-2015 11:17 PM
Taxpayers are spending over $1 billion to send refined fuel to the Israeli military C_R Off-Topic 38 09-13-2012 05:54 AM
