W203 No Fuel Pressure - Page 2 - Mercedes-Benz Forum
post #11 of 28 (permalink) Old 02-28-2018, 05:23 PM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1690 Post(s)
Have you changed the CPS?
- RODNEY
My Stable:
rudeney is offline
post #12 of 28 (permalink) Old 02-28-2018, 06:02 PM Thread Starter
Date registered: Feb 2012
Vehicle: C320 Wagon 2002
Quoted: 2 Post(s)
Originally Posted by Benzyle View Post
You could connect a hose to the schrader valve if you have the right fitting, or otherwise disconnect the fuel line near the driver's side valve cover ,,17mm spanner. and then connect a suitable hose to it to feed into a bucket. Be careful.
If you are sure you have good fuel and good spark and it still wont run the next thing to check is cylinder compression.
Thanks a lot. I found 17mm fuel line connector, and I'll drain gas from there, but I honestly think the gas should be OK, because my wife told me she only got Gas from Costco last few months.
Is it possible that security system error or other electrical issue?
kaigen is offline
post #13 of 28 (permalink) Old 02-28-2018, 06:16 PM
Benzyle's Avatar
Date registered: Nov 2013
Vehicle: MY05 CLK55 AMG , MY05 CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
Quoted: 297 Post(s)
Best of my limited knowledge,if it was a security system or electrical issue you would not be getting a spark and/or fuel delivery.
The fact that you have these means the problem is either water in the fuel/bad fuel or a compression problem.
Unless all fuel injectors stop working somehow ?
Maybe you could remove some spark plugs after some cranking and see if they are wet with fuel to check on this.
Benzyle is offline
post #14 of 28 (permalink) Old 02-28-2018, 06:19 PM Thread Starter
Quoted: 2 Post(s)
Actually when I removed one spark plug after cranking, the plug was wet. Is it normal?
kaigen is offline
post #15 of 28 (permalink) Old 02-28-2018, 06:51 PM
Benzyle's Avatar
Quoted: 297 Post(s)
Yes, that tells you that fuel is being injected into the chamber but is not igniting,which is why the engine does not run.
If you have spark and compression then the only thing left to be at fault is the fuel quality.
Benzyle is offline
post #16 of 28 (permalink) Old 02-28-2018, 07:01 PM Thread Starter
Quoted: 2 Post(s)
Ok, I'll drain fuel from 17mm connector tomorrow. Thanks a lot!
kaigen is offline
post #17 of 28 (permalink) Old 02-28-2018, 07:04 PM Thread Starter
Quoted: 2 Post(s)
Yes, I did it today. I start thinking I didn't push the harness to CPS enough, so I will also check that tomorrow. Thanks!
kaigen is offline
post #18 of 28 (permalink) Old 02-28-2018, 07:09 PM
Benzyle's Avatar
Quoted: 297 Post(s)
Good luck.
But if your CPS is not plugged in then that will be the problem. I think it should 'click' in to place.
Don't drain fuel unless you are sure the CPS is installed properly.
Benzyle is offline
post #19 of 28 (permalink) Old 03-01-2018, 07:33 AM Thread Starter
Quoted: 2 Post(s)
Good luck.
Benzyle, thank you so much! I drained fuel line about one gallon to check the gas quality just turning the key on an off, and the gas "looks" OK, so I reattached the harness to the CPS, and FINALLY the engine started.
But I have another issue, sigh... The idling is very rough below 1500, when the engine runs above 1500, runs just fine. Should I drain all the gas from the tank and the fuel line? I see random misfire and some other misfire code on ODB.
kaigen is offline
post #20 of 28 (permalink) Old 03-01-2018, 09:12 AM Thread Starter
Quoted: 2 Post(s)
This is a OBD2 test result. Cylinder Misfire and Open Loop system failure or such...
File Type: png Screen Shot 2018-03-01 at 12.08.52 PM.png (126.2 KB, 19 views)
File Type: jpg Screen Shot 2018-03-01 at 12.09.51 PM.jpg (76.6 KB, 19 views)
kaigen is offline
