SRS B1039 resistance value in the ignition circuit containing component r12/11 - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 09-27-2017, 06:32 PM Thread Starter
Date registered: Mar 2012
Vehicle: 2010 B200
Quoted: 15 Post(s)
Hello,
2003 C240 4 matic, I have the icarsoft MB II which resets the SRS message but I need to fix the issue for it to go away permanently.
B1039 resistance value in the ignition circuit containing component r12/11 left rear side airbag ignition squib.
Where should I look?
I was thinking to remove door panel - left rear behind driver?
Thanks
oyster is offline
post #2 of 4 (permalink) Old 09-28-2017, 06:06 PM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1687 Post(s)
Yes, R12/11 is the left rear door airbag. This could be a loose wire. Check that there is a good connection to the airbag and trace the wire back through the door hinge.
- RODNEY
My Stable:
rudeney is offline
post #3 of 4 (permalink) Old 09-29-2017, 08:02 AM Thread Starter
Vehicle: 2010 B200
Quoted: 15 Post(s)
think my plan is to disconnect battery, recharge it, then remove door panel, check wires under the plastic cover around door opening, may be put di-electric paste to connectors.
oyster is offline
post #4 of 4 (permalink) Old 06-08-2019, 11:03 AM
DJsBlaccBenz's Avatar
Date registered: Jun 2019
Any luck?
DJsBlaccBenz is offline
