Help - oil / grease around wheel centre - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 09-15-2017, 12:57 AM Thread Starter
donbardan's Avatar
Date registered: Aug 2017
Vehicle: W203 2003 Sedan
Quoted: 12 Post(s)
Hello.
This happened twice so far, I see grease around the wheel centre cap, anyone ?
W203 2003 1.8 Komp Sedan
donbardan is offline
post #2 of 9 (permalink) Old 09-15-2017, 02:41 AM
Benzyle's Avatar
Date registered: Nov 2013
Vehicle: MY05 CLK55 AMG , MY05 CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
Quoted: 297 Post(s)
Probably a good idea to remove the wheel and take a look at the hub assembly. Maybe coming from the wheel bearing cap,clean it up and see where it is coming from.
Benzyle is offline
post #3 of 9 (permalink) Old 09-15-2017, 02:44 AM Thread Starter
donbardan's Avatar
Quoted: 12 Post(s)
Thanks.
I figured it's the bearing yes, I wonder why this is happening.
Not what to look for if I removed the wheel.
post #4 of 9 (permalink) Old 09-15-2017, 02:49 AM
Benzyle's Avatar
Quoted: 297 Post(s)
Maybe the cap is not on properly,allowing grease to leak out.
Look for signs of grease coming out,to fix it just carefully use a hammer to seat the cap correctly.
Benzyle is offline
post #5 of 9 (permalink) Old 09-15-2017, 02:50 AM Thread Starter
donbardan's Avatar
Quoted: 12 Post(s)
Got it. Thank you.
post #6 of 9 (permalink) Old 09-17-2017, 03:48 AM Thread Starter
donbardan's Avatar
Quoted: 12 Post(s)
You were right. It's the bearing dust cap. Damaged in a weird way
post #7 of 9 (permalink) Old 09-17-2017, 05:51 AM
Benzyle's Avatar
Quoted: 297 Post(s)
Wow, I thought maybe it was loose. I wonder how it got damaged? Maybe some sloppy work in the past perhaps.
Were you able to repair it or are you replacing it?
Thanks for the photos.
Benzyle is offline
post #8 of 9 (permalink) Old 09-17-2017, 07:53 AM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1692 Post(s)
Just buy a new one. It does not need to be a genuine part - those caps are pretty much all the same as long as you match the diameter and depth. I'd take it to the local auto parts store and get them to find a suitable replacement.
- RODNEY
My Stable:
rudeney is offline
post #9 of 9 (permalink) Old 09-17-2017, 11:41 AM Thread Starter
donbardan's Avatar
Quoted: 12 Post(s)
Found it on eBay for $9
