Rain sensor lens has air pocket - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 10-16-2016, 07:45 AM Thread Starter
Date registered: Aug 2016
Vehicle: 2003 C230
2003 C230. My rain sensor lens has an air pocket it in. This is causing the wipers not to wip consistently or not at all. I realize the rain sensor lens is a part of the windshield, but I am not about to replace it.
Has any one had this issue and fixed it? What did you do?
Blackner is offline
post #2 of 8 (permalink) Old 10-16-2016, 07:54 AM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1713 Post(s)
You might find a glass shop that can repair it be removing the lens (which will break it), cleaning the adhesive from the glass, then gluing a new lens in place. However, this rarely works. Sit-installed lenses usually end up with bubbles and cause poor sensor performance. The best bet is to replace the glass with one that has the lens installed at the factory.
- RODNEY
My Stable:
rudeney is offline
post #3 of 8 (permalink) Old 10-17-2016, 05:55 PM Thread Starter
Vehicle: 2003 C230
Easy to remove the lens without any damage. Use a heat gun on low on the outside window and on the lens itself. Not much is needed. The adhesive will become soft and then strong dental floss will cut through it.
Now time to figure out a nice optically clear adhesive and put it back together. On a BMW forum they have been using Permatex 66B Clear Silicone RTV Sealant with very good success. Cheap and easy to try anyways.
ID:	1999289   Click image for larger version
ID:	1999297   Click image for larger version
Blackner is offline
post #4 of 8 (permalink) Old 10-17-2016, 06:10 PM Thread Starter
Vehicle: 2003 C230
If for some reason one is very ham fisted, a replacement lens can be had for 30GBP on EEE! bay
BMW MERCEDES RAIN ONLY SENSOR LENS PLASTIC TYPE WITH ADHESIVE PAD | eBay
Blackner is offline
post #5 of 8 (permalink) Old 10-17-2016, 06:32 PM Thread Starter
Vehicle: 2003 C230
Dont try to clean the lens with anything other that your fingernail. Some chemicals will happily run the lens.
Blackner is offline
post #6 of 8 (permalink) Old 10-17-2016, 06:38 PM Thread Starter
Vehicle: 2003 C230
Too bad I cant edit my own posts. Here is a cheaper one from the US. Comes with an adhesive pad.
RAIN SENSOR LENS ALFA ROMEO/BMW/MERCEDES/LAND ROVER PMA K206 | eBay
Blackner is offline
post #7 of 8 (permalink) Old 10-17-2016, 07:46 PM
rudeney's Avatar
Your glass still has a lot of adhesive left on it. That will be a problem.
- RODNEY
My Stable:
rudeney is offline
post #8 of 8 (permalink) Old 10-17-2016, 08:17 PM Thread Starter
Vehicle: 2003 C230
yep - that is obvious.
Also need to clean it off the lens too.
Blackner is offline
