2006 C 320CDi OM642 Engine - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 09-30-2016, 03:42 PM Thread Starter
WuShoozz56's Avatar
Date registered: Jul 2016
Vehicle: 2006 vito 111CDi LWB
Location: Somewhere over the wall where you need a passport!
As many of you will know the above engine has an inherent fault with the Inlet port Shut Off motor down in the bowels of the "V". So mine went in the other day for a look over as I've only just acquired it.. and the news wasn't to great.. this motor has started to get all gunged up, so my thought was to try and clean off the gunge on the motor and linkages using carb cleaner/gunk - but my question is where would the fluid run to during this process a/off the block and on to the ground OR b/ into the engine and create further damage? I choose to do this as a part of preventive maintenance and try and prolong my motor a bit.. anyone any ideas?
WuShoozz56 is offline
