Help!2002 c240 newly replaced key fob won't unlock ignition - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 09-18-2015, 11:22 AM Thread Starter
Date registered: Sep 2015
Vehicle: 2002 c320
I recently got water damage on my 2002 c320 key fob so I went to the dealership to get a new key fob. When the new key fob came in, I put the new fob into the ignition (while at the dealership)and it started to download-not realizing it was doing this I tried to turn the car on-of course it didn't start so then I quickly turned it off and then I turned the ignition back on and it continued to reprogram. We then had to move the car up in line so we had to turn the car off and put in our working key in the ignition-moved the car up in line and then inserted the new fob in the ignition and it began reprograming again. It was taking a long time (we were there about 40 min as it was downloading)so the dealership said we could take the car home and reprogram it at home. We then used our other key-started the car and went home. At home, we put the new key again into the ignition to continue the reprograming and the key would not turn onto the ignition start position (which we had previously done ). Now the dealership says we need to replace the electronic part that is connected with the key ignition stating that we must have crashed the system (our other key works fine) This is very costly-over 1,000 plus once they do this there is no guarantee that the working key of ours will work with the new system. Is it possible that the problem is with the anti theft portion of the car and that when I turned the car on and off three times without completing the data transfer that the system has now locked that key out. Is it possible that all I need is another key instead of their costly solution to the problem? I need an answer FAST!!!! I don't want to spend all this money if there is a simple solution. The dealership states that they tested the new key and that there are no problems with the key
slanedcdc is offline
post #2 of 4 (permalink) Old 09-18-2015, 11:28 AM Thread Starter
Vehicle: 2002 c320
oops I made a misstake in the title of my thread it's a c320
post #3 of 4 (permalink) Old 09-19-2015, 01:56 PM
Purple Moderator
Date registered: Jul 2005
Quoted: 1529 Post(s)
Thread moved to the W203 forum.
Noodles is offline
post #4 of 4 (permalink) Old 09-19-2015, 07:30 PM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1718 Post(s)
It sounds like the dealer sold you a "replacement" key that, when used, will reprogram the EIS to cancel out the old, broken key. Since you 2nd original key still works, you have not "crashed" the WIS. I assume you paid the dealer for a service visit for them to diagnose the bad key and order the new one? What I would do is forget about the "replacement" key and just order an "extra" key. It will com pre-programmed and ready to use with no "download' necessary for the EIS.
BTW, this "programming" that the replacement key does should take about 2 seconds. The dealer not handing this for you is poor service. And even to tell you to go home and keep trying is even worse! I see if they will cover the price of the "extra" key. If you need more details about this, I can describe it, but the DAS (Drive Authorization System) and handling replacement vs. extra keys is not rocket science, but it does take a bit of logic to understand.
- RODNEY
My Stable:
rudeney is offline
