Ignition coil repair procedure. I did. - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 01-31-2015, 05:37 PM Thread Starter
car5car's Avatar
Date registered: Aug 2011
Vehicle: 01 C240 AT
Quoted: 20 Post(s)
Problem: cracked plastic, moisture gets in cracks.
Cleaned with brake cleaner
Blew with compressed air
Heated coil to about 250F with heat gun, I checked temperature with infrared thermometer.
Used RTV to cover all cracks. Do use copper RTV
I had one bad coil (code P0302) but I fixed 2 coils, #1 had cracks too.
Runs perfect!
I will probably do the same to other 4 coils.
car5car is offline
post #2 of 2 (permalink) Old 02-04-2015, 10:17 AM
Date registered: Mar 2010
Vehicle: 88 560SL - 01 C240 - 02 W210 4matic Wagon - W212 4matic wagon
Quoted: 80 Post(s)
In the future I would not use brake cleaner on any plastic/ electronics. But I guess trying to save a coil it will not really matter.
As long as the glue holds up -- it should work.
When you think of the temp swings the coils go though -- especially in very cold weather -- it surprising they don't fail more often.
Thankfully they are not to expensive.
yeldogt is offline
