Front SAM - wiring diagram - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 12-24-2012, 05:20 AM Thread Starter
Date registered: Dec 2012
Quoted: 4 Post(s)
Hi guys. Regarding the contact/sticks under the font sam module.
Does anyone have a diagram or something that shows what the different sticks is for? I want to know what stick (s) that is for the headlights...
Rune,
Rune Kleemann is offline
post #2 of 10 (permalink) Old 12-24-2012, 05:22 AM Thread Starter
Quoted: 4 Post(s)
PS. w203, 220 cdi, year 2001, halogen, left hand drive-
post #3 of 10 (permalink) Old 12-24-2012, 08:58 AM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1713 Post(s)
This may help:
http://benzbits.com/w209/FrontSAM.pdf
http://benzbits.com/w209/FrontSAMWiring.pdf
- RODNEY
My Stable:
rudeney is offline
post #4 of 10 (permalink) Old 12-26-2012, 01:42 AM Thread Starter
Quoted: 4 Post(s)
Thanks. This is what I was looking for. Thanks a lot
post #5 of 10 (permalink) Old 12-26-2012, 02:39 AM
wilsophia's Avatar
Date registered: May 2008
Vehicle: 97 SLK230 Sport Package from HongKong
Send a message via MSN to wilsophia
Do you have the same diagram on Rear SAM please?
wilsophia is offline
post #6 of 10 (permalink) Old 12-26-2012, 04:03 PM
rudeney's Avatar
Here ya go:
http://benzbits.com/w209/RearSAMWiring.pdf
- RODNEY
My Stable:
rudeney is offline
post #7 of 10 (permalink) Old 12-27-2012, 02:21 AM Thread Starter
Quoted: 4 Post(s)
After eliminating wiring faults (from the "sam" to headlights) I have noted that the front sam mudule has to be replaced. I have ordered a similar pre-owned by ebay.
Is it just plug and play, and everything will work? Or does it need to be programmed?
post #8 of 10 (permalink) Old 12-27-2012, 05:19 PM
rudeney's Avatar
If the replacement comes from a car with the exact same options, it may work plug-and-play. A new SAM or one from a car with different options will require coding with SDS.
- RODNEY
My Stable:
rudeney is offline
post #9 of 10 (permalink) Old 01-21-2013, 06:10 AM Thread Starter
Quoted: 4 Post(s)
Running light “flash-problem” solved after replacing the front SAM Module. I bought a used one by ebay, with same A-number. Works perfect , just PLUG AND PLAY! No coding needed.
Skunnyss likes this.
post #10 of 10 (permalink) Old 06-06-2019, 02:12 AM
Date registered: Jun 2019
do you please have the same digram for w221 s550 front sam
kevin.sahib is offline
