Panoramic roof shade - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 03-06-2011, 07:48 PM Thread Starter
Date registered: Sep 2009
Vehicle: 2002 Red C230K SportCoupe
I've been reading through the threads on the c230 coupe panoramic roof problems, but I haven't come across any that describe my particular issue.
1.) My roller blind has somehow detached from its support track or chain that moves it back and forth. That track/chain still works and will push the blind open but it will not pull it closed again. I've made a short video of the problem to better illustrate.
2.) My rear roller blind guides (called a clutch) that slide in the track have broken. So the roller won't move also. Now I'm stuck with front and back open. Any know if this can be repaired without taking down the headliner?
Appreciate any help.
peasngrits is offline
post #2 of 9 (permalink) Old 03-07-2011, 09:33 AM
2002c230's Avatar
Date registered: Jun 2007
Vehicle: 2002 C32 AMG
Think I had this problem... Solution was to not open up the shade completely. My sunroof did not open so that was not a problem.
2002 C32 AMG Sedan [111,000 Miles]
Clear Side Markers | CL Style Grille | Flat Emblem | CF Front Lip Spoiler | CF Rear Diffuser | CF Trunk Spoiler
K&N Air Filters | NGK IX (2 Step) | KV-85 | LET 185MM & ECU | TVT Thermostat | PSK Belt Wrap | CM30
DIY Intercooler Isolation | 26x7x2 FB H/E | Intercooler Reservoir | Battery Relocation | Lorinser Sides
2002c230 is offline
post #3 of 9 (permalink) Old 03-08-2011, 12:12 PM
C230 Sport Coup's Avatar
Date registered: Feb 2007
Vehicle: 2002 C230 Sport Coup and 2006 ML350
Quoted: 32 Post(s)
Download the pano service docs here, if you haven't already. You may find your answer.
2006 ML350 - Stock
2002 C7 Evolution Orion Blue 2.3L C230 Coupe
Auto-Pano-Oyster Leather-Audio 10
AMG Front bar 22mm-17" Wheels- C32 Brakes- H&R 19mm rear sway
TEIN SS Coilovers -
Clear sides- 2005 tails, Blinkers & Grill- Tinted Windows
Bi-Xenons-Clear Fogs- Clear Side/Stealth Bulbs
C230 Sport Coup is offline
post #4 of 9 (permalink) Old 03-09-2011, 04:02 PM
wsw
Date registered: Sep 2010
Vehicle: '05 C230K Coupe
Many thanks for the link. A wealth of information there.
wsw is offline
post #5 of 9 (permalink) Old 03-26-2011, 11:41 PM
Date registered: Mar 2011
shade track
Hi, i think i may have a similar problem. Just wondering if you resolved yours? One of the plastic bits that holds the rear shade in the track broke, so the one side sags. I pulled the shade out of the other sides plastic bit that isnt broken to see how i could replace it. Did you have to replace these pieces?
Did you have to remove the headlining to replace these?
ID:	365659   Click image for larger version
C2ooCoupe is offline
post #6 of 9 (permalink) Old 07-11-2011, 08:40 AM Thread Starter
I just ordered the right side part (clutch) and will have it in a day or two. Already had the left side when I noticed that right was worn. However, I'm still waiting on the front cable and clutch (called a pull in EPC). Yeah the headliner needs to come down for this I believe, so I'm waiting to do the front and back in one job. However, for just the back you may be able to lower only half if you're careful. There goes a full saturday for me.
post #7 of 9 (permalink) Old 05-09-2012, 11:00 AM
Date registered: May 2012
c230 coupe sunshade
The forward portion of the motorized sunshade has dislodged from the motorized clip part on the right side (as you're sitting in the car, looking up)....the left side is still attached. When you attempt to open/close the shade, the right hand clip that rides along the track goes forward/back fine. I can't figure out how to re-attach the clip to the forward edge of the sunshade...the clip looks fine too, hasn't broken. How do those clips attach to the front of the shade? Thanks!
delco5 is offline
post #8 of 9 (permalink) Old 11-21-2017, 11:25 AM
Date registered: Sep 2014
Vehicle: 2008 GL320 and 2007 R320
Part Numbers/Instructions
Sorry to bring back an old thread.... this seems to be the only thread on this that I could find. I have the same problem on my R320. Did you end up pulling the headliner down? Do you know the part numbers for the clips?
dagentooboy is offline
post #9 of 9 (permalink) Old 11-21-2017, 03:27 PM
Date registered: Apr 2017
If anyone has a DIY step by step oh how to fix those things that would be greatly appreciated.. my local junkyard has a c230 coupe with an intact rear sunshade and I wanna attemp to fix it.
Sent from my Pixel XL using Tapatalk
Dmitry Generalov is offline
2002 C230K Coupe - Rear Panoramic Roof Shade Won't Close uncoolfish W203 C-Class 8 04-15-2011 11:08 AM
W221 Roof replacement with panoramic roof? andyhkg W221 S-Class 5 08-14-2009 05:19 AM
Panoramic roof number6 W204 C-Class 3 04-28-2008 03:10 PM
photo of white with panoramic roof / roof spoiler? rebel_mtc W204 C-Class 9 03-26-2008 06:29 AM
Panoramic roof shade Danberg General Mercedes-Benz 0 09-25-2007 10:36 AM
