the engine fan is on all the time?? - Page 3 - Mercedes-Benz Forum
post #21 of 39 (permalink) Old 04-28-2010, 11:03 AM Thread Starter
Date registered: Apr 2010
Vehicle: MB C180 W203 2001
the sensor B12 is broken to tow pice
hello all
i have see the sensor B12 is broken the plastik head is all of and the rest is stell on the pipe i think this is the problem!! :-( now how i will replace it? shuld i get the gas out from the pipe and fel them after ganching the sensor or i can do it direktly, not that the fan is stell working haha. the obd show that the car have no error.
thanx all guys
haltamim is offline
post #22 of 39 (permalink) Old 04-29-2010, 02:06 AM
Date registered: Jul 2008
Vehicle: C200 Kompressor M111 2.0L Avantgarde Year 2002
You can stop the fan by remove fuse NO.51 in the front fuse panel inside the bonet.
Simply unscrew sensor, don't worry the freon will not leak.
W203 C200K M111 2002
Denso Iridium IK20
Ground wires SARD
DangTH is offline
post #23 of 39 (permalink) Old 04-29-2010, 03:09 AM Thread Starter
i have calld the mercedes parts and i will get the sensore tomorow, if i remove the fuse 51 the fan will not working at all, is that ok? even wean the engine can be overheated? or shuld i replace the broken sensore and see what will hapen?
do you have any drawing that i can use as a guid to replace the sensore, and how match shuld i tight the sensore scrow?
thanx for the answering
haltamim is offline
post #24 of 39 (permalink) Old 04-29-2010, 03:38 AM
Yes, the fan will not operate at all. So if you want to start engine or drive the car, you must put the fuse back on.
For the sensor B12, I will try to check spec with WIS program. May take some time and I will update info again soon.
Denso Iridium IK20
Ground wires SARD
DangTH is offline
post #25 of 39 (permalink) Old 04-29-2010, 04:18 AM
B12 Replacement
Please see attach files for info about sensor B12 replacement.
You must have R134a compressor oil and a new seal ring along with the sensor.
Sensor tightening torque is 6 Nm.
ID:	305377   Click image for larger version
Name:	B12 replace.jpg
Denso Iridium IK20
Ground wires SARD
DangTH is offline
post #26 of 39 (permalink) Old 04-29-2010, 04:43 AM Thread Starter
hello
the mercedes guys call me now and thay say that if i unscrow the sensor the freon gas will get out and its vary dangres, thay say the lek well be 100% sure??? shuld i beleav them??
haltamim is offline
post #27 of 39 (permalink) Old 04-29-2010, 08:51 AM
hello
Sorry, I'm wrong. Yes..Mercedes guy is correct, the freon will get out when remove B12 sensor. It is no pin valve inside the pipe block as I see from diagram.
I think you should bring the sensor to the air-con shop for replace and recharge new freon into the system again. Some repair shop could recycle the old freon to recharge again for saving cost of new freon too.
You may think of changing the dryer cartridge in the same time also for better cooling performance.
Name:	AC Part NO.jpg
Denso Iridium IK20
Ground wires SARD
DangTH is offline
post #28 of 39 (permalink) Old 04-30-2010, 01:13 AM Thread Starter
shuld i bay the sealring allso or i will get it directly with the sensor?
thanx allot for all the digrams that u have send thay was vary helpfull.
one last think whay the fan is stell working? its no mor connection to the temperature sensor (B12)?
allso when i disconnect the outside temperature sensor the fan is off!!
thanx allot for the feedback.
haltamim is offline
post #29 of 39 (permalink) Old 04-30-2010, 01:36 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 600 Post(s)
I have already told you what controls this fan. See post #16!
The exterior temperature sensor is for a/c and driver information - not for coolant control.
keyhole is offline
post #30 of 39 (permalink) Old 04-30-2010, 02:18 AM
The seal ring you may ask at the air-con shop, they may have the same size for you. I think it is rubber O-ring. But if they don't have, you could buy the seal ring from your dealer and also the dryer cartridge if you need to replace too.
If disconnect outside temp sensor, it report minus...Celcies. That's mean the cabin need to be warm. Then the compressor will cut off and the fan is shut down that commanded from climate system.
For sensor B12, I think the sensor logic coud be NC ( normal contact ) when freon pressure low and the fan is shut off.
Other logic, sensor break contact ( contact open ) when freon pressure is high as compressor engage, the fan turn on.
And when the connector disconnected or the wire break, it is the same condition of sensor contact open and the fan turn on. This is my understand.
Other thing in the same sensor is the temperature value that might have effect to fan control too.
I know that some car will switch to safe mode when some sensor malfunction. The air-con still operate and the fan can turn on by command from climate system.
Denso Iridium IK20
Ground wires SARD
DangTH is offline
Constant whine from the engine fan/fan clutch? driver450190 W201 190-Class 4 03-27-2010 12:15 PM
Long time fan, first time owner here. mehugtree Unimog 13 12-17-2008 11:12 AM
engine fan or radiator fan fuse and relays ?? DnBtekhnic W203 C-Class 0 04-21-2008 08:40 AM
Aux fan run when Engine fan runs? Is it possible? Haroundb W123 E,CE,D,CD,TD,TE Class 48 07-22-2007 08:17 AM
E430 engine warning lamp lights up from time to time maciek W210 E-Class 2 10-30-2006 05:51 AM
