the engine fan is on all the time?? - Page 2 - Mercedes-Benz Forum
post #11 of 39 (permalink) Old 04-26-2010, 05:30 AM Thread Starter
Date registered: Apr 2010
Vehicle: MB C180 W203 2001
hello agin
i have het the car on the winter in the front bumper aprox. to the position of the sensor B14, it wasent that bad i have just repent the bumper and thats it, i will try the sensor B12/2 today, and i hope that i well get the problem.
haltamim is offline
post #12 of 39 (permalink) Old 04-26-2010, 09:56 AM Thread Starter
Post ambient temperature sensor (B14)
i have just disconnect the sensor B14 and the fan is just shut down wean i blag that agine the engine fan is starting at once, i found the sensor is out of plase? is thes sensor shuld be in his place to work or i have to change it?
thanx allot for all of u.
haltamim is offline
post #13 of 39 (permalink) Old 04-27-2010, 02:45 AM
Date registered: Jul 2008
Vehicle: C200 Kompressor M111 2.0L Avantgarde Year 2002
You can try replace it but you may try unplug the sensor B12 too.
Either one may be the cause.
I think the B14 sensor is the outside temp sensor that climate system use to compared with cabin temp sensor. If the temperature is different, the climate control will decide to blow cold or hot air depended on the temp different.
In case the out side temp is hotter than the cabin inside, the compressor will engage and the fan will operate, the cold air blow to the cabin.
Incase the out side temp is colder than the cabin, the compressor will not operate, the hot water valve will open and blow the hot air to make cabin warm.
About the B12 sensor, it is refrigerant pressure sensor and freon temp sensor in the same body.
When the compressor engage that make high pressure in the freon circuit, the sensor B12 control the fan to be on or off. It is act as fan controller and safety switch. It will cut off the compressor if the pressure is too high.
W203 C200K M111 2002
Denso Iridium IK20
Ground wires SARD
DangTH is offline
post #14 of 39 (permalink) Old 04-27-2010, 04:01 AM Thread Starter
The B12 sensor
but wean i put the climate fan in the cabin on ziro isn't that shut down the compressor and that make no need for the sensor B12 to tern the fan on, abut three monthes ago the tempretur whas (-15 C) and the fan is stell working and the climate system was on the max tempreture (28) and that debent on the whorm water only as i think, any way i will unblag the B12 sensor and see.
thanx for all the answers it was vary helpfull
tanx agine
haltamim is offline
post #15 of 39 (permalink) Old 04-27-2010, 09:55 AM
The fan could be switched on by the engine-radiator temp and the working condition of climate system. It's not too easy to decide.
I think B12 is independently by it's own with some related logic with climate system.
It will still switch the fan on untill freon pressure-temperature drop to the lower level that B12 switch off the fan.
I suspect that the B12 is stick to be on all the time. This may be because of sensor short circuit. You can measure with meter to know it's logic, by pull the plug out and measure the contact pins.
Denso Iridium IK20
Ground wires SARD
DangTH is offline
post #16 of 39 (permalink) Old 04-27-2010, 11:23 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 600 Post(s)
haltamim
Assuming that you have engine type 111, your coolant temperature is monitored by a temperature sensor in the coolant thermostat with electrical signals controlling your electric fan. That's where I would look to solve your fan problem.
keyhole is offline
post #17 of 39 (permalink) Old 04-28-2010, 03:51 AM Thread Starter
connect to OBD2
i have a freand that he have an OBD2 and he say that i can connect it to my car to run an electrical search, in the manual thear is allot of cods and one of them was abut the sensore B12.
yasterday i drive without the outside temreture sensore and evry think was OK unliss its shown the out tempreture is -40 and i havent any problem weth the engine whorm,i try to get the out temp. sensore agen and the fan start to working, i try to reach the B12 sensor but its start to rigen and i stopet i will do it today hopfuly.
thanx allot for helping me. i am sure that will help other who will get thes problem allso( hopfuly non will get that issue)
Best regards
haltamim is offline
post #18 of 39 (permalink) Old 04-28-2010, 09:24 AM
Yes you can check the code
DCT table:
B1226 - In-car temperature sensor (B10/4)
B1227 - Outside temperature indicator temperature sensor (B14)
B1228 - Heater core temperature (B10/1)
B1229 - Heater core temperature (B10/1)
B1230 - Evaporator temperature sensor (B10/6)
B1231 - ECT sensor (B11/4)
B1232 - Refrigerant pressure sensor (B12)
B1233 - Refrigerant temperature sensor (B12/1)
B1234 - Sun sensor (B32)
B1235 - Emissions sensor (B31)
B1241 - Refrigerant fill
B1416 - Coolant circulation pump (M13)
B1417 - Duovalve (Y21y1), left
B1418 - Duovalve (Y21y2), right
B1419 - Electromagnetic clutch (A9k1)
B1420 - Idle speed increase
B1421 - Pulse module (N65)
B1422 - Series interface (K1) connection to instrument cluster (A1)
B1423 - Switchover valve block (Y11)
B1424 - Activated charcoal filter actuator (A32m2) open
B1425 - Activated charcoal filter actuator (A32m2) closed
B1432 - Non-USA DTC
B1459 - Series interface (K2) connection to instrument cluster (A1)
B1462 - Wide open throttle (WOT) position signal: diesel engines
This is for W140 W210
I'm not sure if it the same on W203 or not.
Denso Iridium IK20
Ground wires SARD
DangTH is offline
post #19 of 39 (permalink) Old 04-28-2010, 09:29 AM
I found this from
W203 air conditioning diagnostic mode (C320/C32 only) - MBWorld.org Forums
Push "0" and "EC/REST" button simultaneously until display changes (approx. 5 seconds)
If not work :
On 2002 C32 (digital A/C)
While the vehicle is on and the A/C is in operation, hold down the “REST” button for several seconds until the system goes into the A/C diagnostic mode.
On C32,
Pressing AUTO LEFT Side for 'up' and AUTO RIGHT Side for 'down'
On other C-class A/C,
Pressing “Air up' and 'Air down'
you can shift thru various a/c diagnostic registers.
Cycling through will show you the diagnostic register and its corresponding value.
I've only included the values that may be of interest to owners
00: Interior temp sensor
01: Interior temp sensor
02: Ambient temp sensor
05: Evaporator temp. sensor
06: Engine coolant temp.
07: refrigerant pressure
08: refrigerant temp.
16: carbon monoxide value
17: nitrogen oxide value
18: dewpoint temp.
21: engine RPM
22: vehicle speed
24: battery voltage (very handy)
Denso Iridium IK20
Ground wires SARD
DangTH is offline
post #20 of 39 (permalink) Old 04-28-2010, 09:58 AM
List of Benz OBD2 Code :
OBD Codes - Mercedes Benz Guide and Repair Wiki
Denso Iridium IK20
Ground wires SARD
DangTH is offline
Constant whine from the engine fan/fan clutch? driver450190 W201 190-Class 4 03-27-2010 12:15 PM
Long time fan, first time owner here. mehugtree Unimog 13 12-17-2008 11:12 AM
engine fan or radiator fan fuse and relays ?? DnBtekhnic W203 C-Class 0 04-21-2008 08:40 AM
Aux fan run when Engine fan runs? Is it possible? Haroundb W123 E,CE,D,CD,TD,TE Class 48 07-22-2007 08:17 AM
E430 engine warning lamp lights up from time to time maciek W210 E-Class 2 10-30-2006 05:51 AM
