ABS/ESP/BAS error in hot weather - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 07-14-2009, 06:25 AM Thread Starter
Date registered: Feb 2008
Hello,
During hot summer, when I park the car in direct sunlight, it gives ABS/ESP/BAS error.
When I start it in early morning, (relatively cool weather), it doesn't give such error. (I never experienced such error in winter)
What can be the possible reason?
Somehow, can it be related to expansion of the wire connection? (sounds silly :P )
ccaglayik is offline
post #2 of 8 (permalink) Old 07-14-2009, 07:47 AM
2002c230's Avatar
Date registered: Jun 2007
Vehicle: 2002 C32 AMG
First thing I would check is the ESP ground connection. There is an issue on certain models where the plastic covering on the terminal connection is too close to the connection. There's a DTB section that basically tells you to cut off the plastic closest to the terminal. If that's not the problem it couldn't hurt to clean up the ground connections anyways.
You need to fill out your profile with model, year, etc... Make a signature too!
2002 C32 AMG Sedan [111,000 Miles]
Clear Side Markers | CL Style Grille | Flat Emblem | CF Front Lip Spoiler | CF Rear Diffuser | CF Trunk Spoiler
K&N Air Filters | NGK IX (2 Step) | KV-85 | LET 185MM & ECU | TVT Thermostat | PSK Belt Wrap | CM30
DIY Intercooler Isolation | 26x7x2 FB H/E | Intercooler Reservoir | Battery Relocation | Lorinser Sides
2002c230 is offline
post #3 of 8 (permalink) Old 07-14-2009, 12:53 PM
Date registered: Sep 2004
Vehicle: C240 2003, Sedan, V6
Hello 2002c230,
Could you expand on your answer to CCAGLAYIK a little more? I also have a problem that is related to random ESP errors (and dashboard resets) after starting my C240 in hot weather.
Is the ESP module under the dash? around the steering column? engine compartment?
Thanks,
Jim
'03 C240, automatic
cunningjim is offline
post #4 of 8 (permalink) Old 07-14-2009, 10:16 PM
2002c230's Avatar
The ESP module in located in the engine bay. Not sure of all models, but the majority I have looked at the ESP module is in the same location. It's on the drive side of engine bay. Very noticeable as it has six metal tubes running into the top of the unit. The ground is located a little more over on the drive side next to the module. You will see multiple wires running to the chassis ground. If you need a photograph please let me know...
2002c230 is offline
post #5 of 8 (permalink) Old 07-15-2009, 09:57 AM
2002c230,
Perhaps a photo would help. I have seen a unit in the engine compartment, driver's side with 6 pipes running from it to the engine block. I always thought it was part of the fuel distribution system.
Related question: Is it necessary to reinitialize SAM's after reconnecting the battery?
Thanks,
post #6 of 8 (permalink) Old 07-16-2009, 12:00 AM
2002c230's Avatar
No, it is not part of the fuel system. That is the ESP module. All power window features, and the ESP must be reinitialized after disconnection of the battery.
2002c230 is offline
post #7 of 8 (permalink) Old 07-16-2009, 12:10 AM
Thanks for the photo and the feedback.
post #8 of 8 (permalink) Old 06-14-2019, 10:13 AM
Date registered: Jun 2019
turrrr
Did you figure out what was the problem? I have same situation.....
sirturek is offline
ESP/BAS/ABS KADE W210 E-Class 17 12-01-2013 08:08 AM
Help! ESP/BAS error on my 98 e55 projectG W210 E50 AMG, E55 AMG 8 07-29-2010 11:01 AM
BAS/ESP/ABS tran691 W163 M-Class 9 12-27-2008 05:42 PM
Cold Weather and BAS/ESP Light?? Steve (Austria) W163 M-Class 3 01-23-2008 03:57 PM
BAS ESP ABS Frank C208/A208 CLK-Class 3 08-06-2004 09:41 PM
