Driver Side Parking Lights staying on - Page 2 - Mercedes-Benz Forum
post #11 of 16 (permalink) Old 05-13-2019, 02:52 PM
Date registered: Jan 2018
Vehicle: 2007 C220 CDI Avantgarde W204
Quoted: 4 Post(s)
Thanks Kevin. It looks like I need not ask for your help again as Dr Google has come up with two suggestions how to remove the switch. One video removes the panel on the side, the other just seems to use repeated twisting and turning to pull the switch out.
domwild is offline
post #12 of 16 (permalink) Old 05-13-2019, 07:19 PM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1695 Post(s)
Maybe this will help:
http://benzbits.com/w203/HeadlightSwitch.pdf
- RODNEY
My Stable:
rudeney is offline
post #13 of 16 (permalink) Old 05-13-2019, 07:50 PM
KevinH2000's Avatar
Date registered: Jul 2017
Vehicle: 2005 C230 Sedan, 6 Speed MT
Quoted: 16 Post(s)
There is a torx fastener hidden under the parking brake handle.
KevinH2000 is offline
post #14 of 16 (permalink) Old 05-28-2019, 06:01 PM
Date registered: Sep 2015
Vehicle: 2004/5 W203
Quoted: 41 Post(s)
Most often the cause is an exposed wire on that circuit touching the body of the car. Find that and insulating will generally fix the issue.
Hutcho85 is offline
post #15 of 16 (permalink) Old 05-29-2019, 03:49 PM
Quoted: 4 Post(s)
Thanks for help. As there is no after-market light switch available, I have to buy a Merc one from Hawaii and the cost + postage is AUS$600 or US$360, and that is mucho dinero. If the flaw perists, I will have to fork that out obviously as draining a battery is also not wise, that reduces the life.
One hopes that a faulty light switch is the problem as paying for a Merc technician to find rubbing wires somewhere must be very costly at AUS$270/hr. Due to the lack of rain here in Western Australia, rain having entered the front driver side SAM does not seem to the issue as told by a Merc mechanic.
domwild is offline
post #16 of 16 (permalink) Old 05-29-2019, 03:56 PM
Quoted: 41 Post(s)
Dom, Take it to an Auto Sparky, they'll find it and fix it for maybe $100.00. It is certainly NOT a $600.00 repair.
Hutcho85 is offline
Brake Lights Staying ON Al W220 S-Class 6 01-24-2019 11:33 AM
No lumbar support and parking lights on one side bigbux98 W140 S-Class 3 04-20-2008 10:26 AM
abs / asr lights staying on benzs23 W140 S-Class 4 12-07-2005 09:40 AM
Driver side parking lights STAY on?! BMS_Ken R170 SLK-Class 5 05-09-2004 09:46 AM
need help....interior lights staying on !! CI300CE W140 S-Class 4 01-12-2004 08:21 PM
