02' C230K cup holder removal & repair - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 06-25-2007, 09:05 PM Thread Starter
2002c230's Avatar
Date registered: Jun 2007
Vehicle: 2002 C32 AMG
Hi again everyone. Today I was driving a friend to town, and washed my car. She decided to stay in the car, and when I got back in guess what? Apparently she thought it would be fun to "mess around with" my cup holder, and yes, she broke part of it.
I had orginally wanted to remove the cup holder anyways, because I need to remove loose change stuck in the holding area of the cup holder so it will actually close. Searched the forum for a "how to" on this, but only found a few vague posts.
pull the soft bottom pad out, twist it with some force and comes right out.
open the cup-holder, pull out the plastic bottom piece, turn the holder towards the passenger and pull.)
This seems simple enough, but I tried it without any luck. Feels as if I'm just going to break it pulling any harder. As I said, the posts are also to vague. So, the steps would simply be...
Removal;
1. Open cup holder. (Simple enough...)
2. Pull out the rubber bottom piece. (Easy to do...)
3. Turn the cup holder towards the passenger. (Turn it left or right towards passenger seat, and how much force to apply?)
4. Pull on it. (Which direction, and how much force to apply?)
I will include a photograph to orientate the direction at which to write out the instructions.
Installation;
1. No information available that I can find. (How to reinstall?)
Repair;
So what's broken? The piece that applies pressure to smaller cups. Spring loaded. I believe it may be missing a small metalic "connection" the joins the top part to the piece to the top bottom side of the cup holder. I would assume that I cannot ever find this small piece, and will just have to buy a new cup holder?
1. No information available that I can find. (How to repair, if possible?)
Attached is the photograph that also shows the broken piece. I appriciate any help. Attachments was not working for some reason, so I have uploaded it to another image hosting provider.
Thanks,
Matt
2002 C32 AMG Sedan [111,000 Miles]
Clear Side Markers | CL Style Grille | Flat Emblem | CF Front Lip Spoiler | CF Rear Diffuser | CF Trunk Spoiler
K&N Air Filters | NGK IX (2 Step) | KV-85 | LET 185MM & ECU | TVT Thermostat | PSK Belt Wrap | CM30
DIY Intercooler Isolation | 26x7x2 FB H/E | Intercooler Reservoir | Battery Relocation | Lorinser Sides
2002c230 is offline
post #2 of 13 (permalink) Old 06-26-2007, 04:01 PM
Date registered: Aug 2005
Vehicle: 02 C32, 08 C350, 00 CLK320 (sis'), 01 ML430 (gone)
Send a message via AIM to FrankW Send a message via MSN to FrankW
you are not using enough force twisting/rotating it.
2002 M112K with lots of mods
2008 M272 with some mods
For Sale:
$100
FrankW is offline
post #3 of 13 (permalink) Old 06-27-2007, 03:44 AM Thread Starter
2002c230's Avatar
So it doesn't matter which direction I turn it slightly before pulling? Do I just pull it straight out towards the driver side seat or up any at the same time? Is pulling it out just disconnecting its clips that hold it in place or breaking them? Is the broken cup pressure piece repairable? I tried to repair it without any luck. It would not stay in place, which is why I believe there is a small "connection rod" that joins the two missing. To place the cup holder back in I would just jam it in with about as much force as it required to pull out?
Thanks,
Matt
2002c230 is offline
post #4 of 13 (permalink) Old 06-27-2007, 01:38 PM
cup holder's held on by clips. you won't break the clips. it slides in easier than it slides out. you won't be able to repair the pressure piece if you are looking at broken plastics. just go to your dealership and order a new one.
For Sale:
$100
FrankW is offline
post #5 of 13 (permalink) Old 06-27-2007, 07:39 PM Thread Starter
2002c230's Avatar
Alright, thank you for the reply FrankW. Appriciated.
2002c230 is offline
post #6 of 13 (permalink) Old 01-14-2009, 05:28 AM
Date registered: Aug 2008
Hi, Did this help you to remove the whole cup holder??
nilay is offline
post #7 of 13 (permalink) Old 01-14-2009, 08:33 AM
Black04C230's Avatar
Date registered: Mar 2008
Vehicle: 2004.5 C230 Kompressor Sport Sedan
Never leave bored women in your car.... They always look through everything and make a mess or break something.
2004.5 C230 Kompressor Sport Sedan.
C55 Lip Spoiler, Roof Spoiler, 3 Fin Grill, Flat Hood Emblem, Clear Corners, Projector Headlights, Eyelids, Projector Foglights, Brabus Door Pins, Smoked Tail Lights, Smoked Third Brake Light, and Window Tints.
Next: C63's & AMG facelift.
Black04C230 is offline
post #8 of 13 (permalink) Old 01-14-2009, 10:28 AM
UK-C200's Avatar
Date registered: Nov 2007
Vehicle: RHD C200K Sport Coupe, RHD SLK-55, LHD SLK-350
Close, but no cookie :-)
Never leave bored women anywhere.... They always look through everything and make a mess or break something.
UK-C200 is offline
post #9 of 13 (permalink) Old 01-14-2009, 10:54 AM
True True. You are right on with that one.
post #10 of 13 (permalink) Old 01-15-2009, 01:15 AM
Has anyone managed to remove the cup holder unit. I need to replace the pressure spring
nilay is offline
Help: Armrest Removal and Fix for Rear Cup Holder RestyB W163 M-Class 11 03-05-2015 10:54 PM
Cassette Holder to Cup Holder Conversion worrell100 R129 SL-Class 181 05-23-2014 11:58 AM
Flip up cup holder removal jmel777 W211 E-Class 6 05-22-2010 08:46 AM
02' C32 vs. 05' C230K - Buy which one? natedwm General Mercedes-Benz 2 02-22-2007 06:48 AM
Wheels for 02' C230K Guest (MBNZ) The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 05-03-2002 03:43 PM
