DIY - air filter change - Page 2 - Mercedes-Benz Forum
post #11 of 52 (permalink) Old 01-27-2009, 12:13 AM
Date registered: Feb 2008
Can a dirty air filter, cause secondary air intake code?
akapotency is offline
post #12 of 52 (permalink) Old 03-09-2009, 09:43 AM
W.2.0.3's Avatar
Date registered: Jun 2008
Vehicle: C200 (W203)
Send a message via MSN to W.2.0.3 Send a message via Yahoo to W.2.0.3 Send a message via Skype™ to W.2.0.3
Hey guys,
I'm looking forward to buy this K&N air filter ..
but it doesn't look like the one in the pictures ??!!
33-2193 - K&N Replacement Filters, Replacement Air Filter
I have a C200 Kompressor 2001
so if there any guide can help me fix this one ??
Regards,
W.2.0.3 is offline
post #13 of 52 (permalink) Old 03-14-2009, 03:10 PM
Date registered: Jun 2007
Excellent pictures! Will be doing mine soon. This is a huge help?
rayabello is offline
post #14 of 52 (permalink) Old 03-14-2009, 03:17 PM
I would not recommend going with an oil impregnated airfilter. This sometimes let's oil go into the MAF Sensor filaments and kills the MAF. This happened to me on a naturally aspirated MB V6. When I replaced the MAF I went back to a stock airfilter. A supercharged engine will bring in more air volume making this risk even higher (same with cold air intake).
post #15 of 52 (permalink) Old 03-16-2009, 11:10 AM
Kompressor05's Avatar
Date registered: Dec 2008
Vehicle: '05 C230 Kompressor
Just swapped out my dirty filter with a new one (no K&N) Took minutes. No zip tie cutting, just undid the hex bolts cleaned out the bottom of the air box, dropped in the new one than put it all back together.
Analrapist, the world's first combination analyst and therapist.
Kompressor05 is offline
post #16 of 52 (permalink) Old 03-17-2009, 03:58 PM
c32used's Avatar
Date registered: Oct 2006
Vehicle: 2002 LET POWERED C32
nice DIY write-up.
LET 185mm+Custom Tune+SL55 full setup W/ITG filters
C32 OEM pulleys F/S
Newbie search
Kenwood DNX7100
LEARN TO PLAY MYSPACE MOBSTERS BETTER PM ME
c32used is offline
post #17 of 52 (permalink) Old 04-05-2009, 06:59 PM
Date registered: Apr 2009
The pictures don't make sense in my 2002 C230 Kompressor coupe.
33-2193 - K&N is the replacement filter and it is rectangle.
remicat is offline
post #18 of 52 (permalink) Old 04-12-2009, 11:25 AM
W.2.0.3's Avatar
this is what I'm talking about ..
mine too doesn't look like the one in this tutorial
W.2.0.3 is offline
post #19 of 52 (permalink) Old 05-24-2009, 01:43 PM
victorcaloca's Avatar
Date registered: Jul 2008
Why messing with the zip tie? is it on the way of removing the AIR FILTER cover?
_______________________________
***** 2004 C-230 Kompressor Sport 65k Miles
victorcaloca is offline
post #20 of 52 (permalink) Old 06-02-2009, 01:15 PM
Vehicle: 2005 C230 Kompressor Sport Sedan
http://www.autopartswarehouse.com/po...BBaXIgRmlsdGVy
Is this the right one for my car?
The "Stealership" wants $115, I'd rather get the same thing for $25.95 and do it myself!
But I just want to know if I am buying the right filter for my 2005 C230 Kompressor Sedan with Sport Package...thanks
Meltdbutta is offline
