car crank but do not start - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 07-30-2018, 07:20 AM Thread Starter
Date registered: Jul 2018
CAR(w202) crank prefect but do not respond after changing low arm....I have change the crank sensor,change the k20 and also change the fuel pump but still the same problem.... any ideal please????
Kelvin Packline Kim is offline
post #2 of 8 (permalink) Old 07-30-2018, 05:30 PM
Date registered: Dec 2012
Vehicle: 1999 w202 c240
Quoted: 10 Post(s)
Is it getting any fuel? Undo the blanking off nut on the gas supply rail. You will find a bicycle type falve benith the nut , the valve open....press in the shaft on the valve, , attempt to run the motor , if you covered in fuel/gas that part is working.then you will have to check all the censors good luck
Sent from my GT-N8000 using Tapatalk
alf_hockly is offline
post #3 of 8 (permalink) Old 07-31-2018, 07:16 AM
Moderately subtle
edfreeman's Avatar
Date registered: Dec 2003
Vehicle: 94 E500, 97 500SL
Quoted: 175 Post(s)
Send a message via AIM to edfreeman
Is this a C36 or C43? If not, you're in the wrong forum and will likely get more responses in our normal W202 section.
edfreeman is offline
post #4 of 8 (permalink) Old 07-31-2018, 09:46 AM Thread Starter
Thanks for trying to help but it w202 and am able to fix it
post #5 of 8 (permalink) Old 07-31-2018, 09:52 AM Thread Starter
it a wrong message I have sent... the car is w202 and it responds now but the fire doesnot stand on
post #6 of 8 (permalink) Old 07-31-2018, 09:56 AM Thread Starter
Thanks but it respond now but you cant rise the fire of the car and the fire does not stand on..... the car is w202
post #7 of 8 (permalink) Old 05-13-2019, 10:57 AM
Date registered: Jan 2009
Vehicle: 98 5.4 c43, 05 c55
Quoted: 2 Post(s)
Try the k40 relay. I heard this can cause it
PJmak is offline
post #8 of 8 (permalink) Old 06-08-2019, 07:59 PM
khomer2's Avatar
Date registered: Nov 2015
Vehicle: w163 02 ML500 W210 97 E50Amg w202 99 C230K w124 - need more space, time to build again
Quoted: 218 Post(s)
Did you scan for codes saved?
Please update your user CP info with the rest of the info.
Name:	user cp info benzworld.jpg
khomer2 is offline
  Mercedes-Benz Forum > Mercedes-Benz AMG Forums > W202 C36 AMG, C43 AMG
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
