Anyone know how to adjust clutch on sunroof motor please? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 08-07-2003, 10:57 PM Thread Starter
Date registered: Feb 2003
My mum's got a L reg (1993/4) c180 with just 11k on the clock!
However, the previous owner never used the sunroof, and my mum has only just started to use it this week, due to to heatwave here in the UK.
This means that the sunroof is a bit stiff.
I have WD40'd the rails every 6 months or so, and this makes it appear to move smoothly, however, the windows and sunroof are wired to the clifford alarm to automatically close, and when closing by remote, the sunroof now closes, but the rear edge remains approx 1/2 cm too low, but if manually closed, it closes correctly.
This led me to try and change the clutch setting.
On a w126 post i read the motor was in the boot!, but all i could find was electric ariel and (i think) fuel pump.
Does anyone know where the motor is, and how to adjust the clutch?
And before any smart ass says just close it manually, I would, but this is for my mum who forgets things like this every now and then - this problem only came to light when she left her car overnight and returned to find it with sunroof only 2 inch shut in the morning!
RobinG is offline
post #2 of 4 (permalink) Old 08-12-2003, 03:02 PM
Date registered: Nov 2002
Vehicle: SL280
I think you might do well to check the rails for any signs of preventing it closing. The r...
I think you might do well to check the rails for any signs of preventing it closing. The runners have some limited adjustment which might do the trick.
I had one where the roof was not running square in the runners which never really got sorted despite many adjustments.
The motor is in the boot - follow the cable rack down from under the parcel shelf. I cannot remember though if it has any cutch adjustment. Does the motor sound as if it is running on despite the roof not closing or does it labour? if the latter, doubt its clutch..
Hal
J62105 is offline
post #3 of 4 (permalink) Old 08-14-2003, 11:41 PM
Date registered: Aug 2003
RobinG, there is a resistance sensor built-in to the module that controls the closure of...
RobinG, there is a resistance sensor built-in to the module that controls the closure of the sunroof that is connected to your alarm system.
Since the old owner havent ever used the sunroof, that means the alarm was trying to close the sunroof every time the alarm was turned on even the roof is closed thus making the module more sensitive to the resistance causing to automatic shut-off before it is even closed completely.
it is a safety feature in case someone gets their arm, hand, or whatever stuck when the roof is closing.
Try "helping" the roof close when you turn on the alarm system by pushing it forward and if it does the trick, then you either need a new module with adjustable resistance settings and or check the guage of the wire that leads to the module(14ga-16ga min or connection problem)also ground wire, or you may need a new motor(if the tracks and rails are smooth) or just close it manually with the switch(switch always works cause it doesnt have to do with the module)module usually has a independent suplly and if branched off to other power draining components can cause this problem also.
SPortMP5
SportMP5 is offline
post #4 of 4 (permalink) Old 08-22-2003, 05:00 PM Thread Starter
Thanks a lot for info.
RobinG is offline
