98 C280 Antenna Location - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 07-10-2019, 02:36 PM Thread Starter
Franklyspeaking's Avatar
Date registered: Feb 2015
Vehicle: 1998 C280; 1987 560SL
Quoted: 85 Post(s)
I have searched for and read a ton of stuff on this subject, but I have not found anything definitive on the location of "my" particular car's FM/AM antenna. I get very bad radio reception and it simply must be improved. I hate the thought of removing the carpets and possibly a seat to route another cable to the rear of the car. My car has a short 10" antenna on the on the back glass, but I think it must be a cell antenna, as unplugging does not affect radio reception at all.
I took the trunk apart last night, but did not see the antenna wire. I did find a couple of coax cables that looked like cell phone stuff on the drivers side. From the radio it appears to drop down to the floor on the passenger side and head to the back. If no one can help I guess I will have to tear out the interior this weekend to find it!
Franklyspeaking is offline
post #2 of 5 (permalink) Old 07-10-2019, 04:22 PM
khomer2's Avatar
Date registered: Nov 2015
Vehicle: w163 02 ML500 W210 97 E50Amg w202 99 C230K w124 - need more space, time to build again
Quoted: 275 Post(s)
Have you checked the fuses for the radio? One is typically for the radio amplifier.
khomer2 is offline
post #3 of 5 (permalink) Old 07-10-2019, 07:11 PM Thread Starter
Quoted: 85 Post(s)
Yes, I have the Bose sound system and the amplifier is working properly. All of the fuses test okay. I do not see one listed for an antenna amplifier. I would like to find the antenna, so I can see if cleaning the connections or if the grounding is proper.
post #4 of 5 (permalink) Old 07-11-2019, 12:40 PM
Date registered: Aug 2013
Vehicle: W201 2.5-16 manual, W202 230K Sport manual & a few non Merc's
Quoted: 34 Post(s)
The antenna is built into the rear window. I'd have doubts the antenna (screen) that's at fault, unless the element is damaged. Does the rear screen demister operate 100%?
Still learning, still breaking things...still spending!
John Jones Jr. is offline
post #5 of 5 (permalink) Old 07-11-2019, 07:06 PM Thread Starter
Quoted: 85 Post(s)
The rear window has a heating coil and works fine. The past few months I have had to park it outside, and I use it everyday. The antenna is not visible in the rear window glass. I had read some threads that indicated the antennas were visible apart from the heating elements. I see no other wires in the glass. Perhaps this is wrong - are the heating wires and the antenna one and the same?
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
M_Davis
