95 c280 lights left on, battery died no sound at jump - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 06-25-2019, 08:03 AM Thread Starter
Date registered: Jun 2006
Vehicle: 1995 c280
Angry 95 c280 lights left on, battery died no sound at jump
Last night, I left my lights on and after about 1 hour came back to see dim lights. cop tried to jump, no sound at all. called insurance and towed to house. googled information 1. corrosion 2. starter 3. alternator. did anyone go through same, please advise. I will purchase scanner and update the report.
Thanks.
sirphira is offline
post #2 of 7 (permalink) Old 06-25-2019, 10:16 AM
khomer2's Avatar
Date registered: Nov 2015
Vehicle: w163 02 ML500 W210 97 E50Amg w202 99 C230K w124 - need more space, time to build again
Quoted: 269 Post(s)
No history other than a dead battery so...
"Jumping" will not necessarily get you going if the battery is deader than dead.
When was the last time you replaced your battery? You do realize they too have a limited lifespan, right?
You need a real booster.
One of these - it's a chick (and neighbor) magnet
Free BBQs, meals and beer most of the time.
sirphira likes this.
khomer2 is offline
post #3 of 7 (permalink) Old 06-25-2019, 10:48 AM Thread Starter
Vehicle: 1995 c280
battery replacement, got it.
scanner shows p1700 and p1444.
how about preventive measure. is there any product or mechanism that lights go off if left on by mistake? i will appreciate input as proactive measure.
Thanks.
sirphira is offline
post #4 of 7 (permalink) Old 06-25-2019, 11:00 AM
khomer2's Avatar
Quoted: 269 Post(s)
Thanks.
P1444 is a EVAP code.
P1700 is for a tranny upshift delay, typically caused by a vacuum leak somewhere.
You need to check all your vacuum lines for breakage and hairline cracks, or you can opt to do a smoke test
Erase the codes and test again to see if the codes reappear.
https://www.benzworld.org/forums/w20...e-problem.html
As for preventative measures, nothing worth installing imo unless you have $$ to burn.
Treat it like a baby.... "if you dont feed the baby, the bay will die"
khomer2 is offline
post #5 of 7 (permalink) Old 06-25-2019, 11:54 AM Thread Starter
Vehicle: 1995 c280
battery changed --> starts perfecto
Thanks a lot.
Changed battery from Sams
Wallah, it works again
Still have concern, the cop tried to jump and there was no sound (not even faint clicking), mystery
All is well that ends well.
Thanks Khomer2
sirphira is offline
post #6 of 7 (permalink) Old 06-25-2019, 01:07 PM
khomer2's Avatar
Quoted: 269 Post(s)
Even a jump to a dead battery can give you a 'no click' (depending on the condition of the battery)
khomer2 is offline
post #7 of 7 (permalink) Old 06-26-2019, 07:34 AM
MB-W202's Avatar
Date registered: May 2010
Vehicle: 1995 C280 (165K mi)
Quoted: 128 Post(s)
Learn about batt maintenance online. Lots of info. Easy.
Erase the codes and check them again in a few weeks. If they come up again search the forum. Those are common fault codes.
How many miles? As stated your car has lots of vacuum tubes which are brittle and needs changing. Also, have you replaced the engine and trans wiring harness? They're definitely a goner.
MB-W202 is offline
