OBD - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 06-18-2019, 06:07 AM Thread Starter
Date registered: Dec 2017
Vehicle: 1994 , C220
Quoted: 7 Post(s)
OBD
Hi guys..
My w202 has 38 pin obd only, no obd2 connector so i am trying to connect elm327 blutooth to the 38 pin using the cable converter from 38 to 16 pin but its not working ... I attached the picture explaining how to connect the pins ...
Pins number 10,13,15,24,28 are not available in the 38 pin in my car .... Pins available are 1,2,3,4,6,16,17,30
Did anyone tried this before ??? Pls explain to me why it wont work ......
ID:	2521660   Click image for larger version
ghazi197 is offline
post #2 of 8 (permalink) Old 06-18-2019, 07:02 AM
khomer2's Avatar
Date registered: Nov 2015
Vehicle: w163 02 ML500 W210 97 E50Amg w202 99 C230K w124 - need more space, time to build again
Quoted: 275 Post(s)
Not all 38 pin connectors are created equally. Most are garbage - especially the chinese-made ones.
As well, not all scanners are compatible with a proper 38pin connector.
Why not invest in a better scanner? Since you have no obd2 port, this particular device seems useless, imo. The only selling feature of these devices is small, convenient to plug-in (dont leave it in, otherwise they drain your battery dead) and look pretty. And only allows you to read codes, nothing more.
khomer2 is offline
post #3 of 8 (permalink) Old 06-18-2019, 07:38 AM Thread Starter
Quoted: 7 Post(s)
Yeah i know these Bluetooth obd only read codes and does not do a deep scan like pro. Scanners but the idea is i am adding a screen in my car so its a nice feature to add to the android screen and the battery is not a problem i can fix the battery drain by connecting the power to obd bluetooth externally so when turning off the car the obd will turn off ... My only problem is making the obd read the ECU .....☹️
ghazi197 is offline
post #4 of 8 (permalink) Old 06-19-2019, 01:08 PM
Date registered: Mar 2004
Vehicle: Amethyst 2001 C320
Quoted: 5 Post(s)
An adaptor is about $5 on fleaBay: https://www.ebay.com/itm/OBD-OBDII-3...8AAOSwRDJcLbft
n0alpha is offline
post #5 of 8 (permalink) Old 06-20-2019, 05:55 PM Thread Starter
Quoted: 7 Post(s)
I have the adapter but its not working with the elm327 Bluetooth , thats why i am asking about the pins , as you can see in the picture i uploaded i connected the wires according to the picture but it didnt work ....
ghazi197 is offline
post #6 of 8 (permalink) Old 06-20-2019, 06:08 PM
khomer2's Avatar
Quoted: 275 Post(s)
imo, I think your wasting your time looking for a solution to get a cheap bluetooth obd2 device to mate to a cheap generic 38pin adapter.
There are some things that just are not justified.
I dont see how you are saving any time and $$ looking for a fix - your way or the right way..
But hey, it's your time and money. Do what you will, it's your w202.
GL.
khomer2 is offline
post #7 of 8 (permalink) Old 06-20-2019, 06:22 PM Thread Starter
Quoted: 7 Post(s)
Yeah i know its a waste of time but i was just answering the guy who posted the adapter link ... But anyway i found the right scanner for my benz its Foxwell NT530 pro on amazon its 200$ so you are right i am wasting my time on these stupid chinese Bluetooth elm327
ghazi197 is offline
post #8 of 8 (permalink) Old 06-20-2019, 07:46 PM
khomer2's Avatar
Quoted: 275 Post(s)
Foxwell will serve you well.
khomer2 is offline
