Type of Glue to Install Trunk Letters - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 06-12-2019, 07:53 PM Thread Starter
Franklyspeaking's Avatar
Date registered: Feb 2015
Vehicle: 1998 C280; 1987 560SL
Quoted: 82 Post(s)
I took the C280 letters off the trunk lid for a paint job. What glue to use for reinstall?
Franklyspeaking is online now
post #2 of 7 (permalink) Old 06-12-2019, 08:23 PM
260e crusier's Avatar
Date registered: Nov 2010
Vehicle: 1999 E320, 2003 E320 Wagon, 2005 C230K SS, 2010 Accord LX w Eibach & Koni FSD's
Quoted: 491 Post(s)
Leave them off
Use double sided foam tape (3M) if you must.
260e crusier is offline
post #3 of 7 (permalink) Old 06-12-2019, 10:39 PM
khomer2's Avatar
Date registered: Nov 2015
Vehicle: w163 02 ML500 W210 97 E50Amg w202 99 C230K w124 - need more space, time to build again
Quoted: 269 Post(s)
This - you dont need alot of it.
khomer2 is online now
post #4 of 7 (permalink) Old 06-13-2019, 06:39 AM
Date registered: Jul 2010
Vehicle: 1995 C220
Quoted: 214 Post(s)
I agree. The double side tape is the best way, especially if you may need to remove them again without damaging the paint. Any of the other glues (like 3m plastic and emblem adhesive) is a more permanent glue that will damage the paint and is a pain to clean if you make a mess.
The trick to making the double sided tape work is you must have a 100% clean surface. So on your old emblem, make sure you remove all the bits of old tape AND whatever glue residue is behind. Go to a parts store that sells automotive products and get some 3m general purpose adhesive cleaner to soak the emblems in overnight, and the glue and tape will come off easily.
georgebuhr is online now
post #5 of 7 (permalink) Old 06-14-2019, 06:34 AM
Date registered: Aug 2014
Vehicle: 1995 C280 1997 S320
Quoted: 14 Post(s)
I used 3m tape to attach some letters to my Harley tourpack. It was about 8 years ago and the letters are still there.
What I got it wasn't really a double-sided tape but rather some glue on the surface over plastic liner. It comes in a roll just like Double sided Tape and is about quarter inch wide and it's a red color. I was looking for product that is not too thick and I can tell that this tape is very very thin but the quality of the grip is really good. I've looked at different products and they all are based on the tape that is a little bit foamy and then applied glue on both sides. I didn't like that because it would make the letters sit far away from the painted surface.
Look in any automotive stores for that tape. I think it's specifically designed for this purpose
Sent from my LG-H873 using Tapatalk
you can watch all my MB repair videos on
andy_1100 is offline
post #6 of 7 (permalink) Old 06-14-2019, 08:24 AM
Quoted: 491 Post(s)
It's call 3M VHB tape. The bond on this tape actually gets stronger with time. It may not work well for the letters on the trunk. It's too thin to fill the void behind the letters.
EDIT: Sorry for the out off focus picture............
post #7 of 7 (permalink) Old 06-28-2019, 07:14 PM Thread Starter
Quoted: 82 Post(s)
The 3M Molding Tape worked great! Thanks for the tip.
andy_1100 likes this.
