1999 C280 rough idle - Mercedes-Benz Forum
LinkBack Thread Tools
Old 06-11-2019, 06:37 PM Thread Starter
Date registered: Jan 2012
I have a 1999 C280 with rough idle issues.
It is most notable when I'm sitting at a traffic light in gear with the air conditioning on.
If I turn off the a/c the idle increases and the vibration stops.
With the a/c on the idle slows and the shaking begins.
If I take it out of gear, the vibration stops, even with the a/c on.
I have had this issue for a few months.
I recently installed new coils, spark plugs, spark plug wires, new valve over gaskets and breather hoses.
This did help, but it only reduced the intensity of the vibrations.
Prior to this I did replace the crank position sensor also.
I would appreciate any suggestions you may offer.
Thank you
my2ndmb is offline
Old 06-12-2019, 09:53 AM
MB-W202's Avatar
Date registered: May 2010
Vehicle: 1995 C280 (165K mi)
Quoted: 128 Post(s)
I think your initial idle is too low. A load when not driving causes it to go below your min idle. You may need to increase your resting idle.
My car idles at ~650 rpm in park. Yours may be different.
MB-W202 is offline
Old 06-12-2019, 11:01 AM
khomer2's Avatar
Date registered: Nov 2015
Vehicle: w163 02 ML500 W210 97 E50Amg w202 99 C230K w124 - need more space, time to build again
Quoted: 273 Post(s)
Concur with MB-w202.
Ours idles at ~650rpm.
khomer2 is online now
Old 06-12-2019, 11:00 PM Thread Starter
That's where mine idles in park also.
I don't think that's the issue.
my2ndmb is offline
Old 06-12-2019, 11:35 PM
Date registered: Aug 2014
Vehicle: 1995 C280 1997 S320
Quoted: 14 Post(s)
First id start looking for possible vacuum leaks..
Second clean MAF sensor
Whats your Long term fuel trim?
Sent from my LG-H873 using Tapatalk
you can watch all my MB repair videos on
andy_1100 is offline
Old 06-14-2019, 10:40 PM
Date registered: Sep 2005
Vehicle: 1999 C280, 2000 C280, 2000 C230K,2011 C300
Quoted: 29 Post(s)
Rough idle in gear at stop.>>>>>>>>>
Smooth idle in neutral at stop.>>>>>>
This is bad engine mounts.
If they haven't been done like ever, then most likely.
Put the car on ramps or jack stands and take a look to see if they are squashed or maybe even leaking oil.
Go to the online parts sites to see what they look like.
glenmore
1999, 2000 C280
2000 C230K
2011 C300
glenmore is online now
Old 06-15-2019, 03:09 PM
MB-W202's Avatar
Quoted: 128 Post(s)
great point glenmore. slipped my mind completely.
yes, check the mounts.
MB-W202 is offline
Old 07-02-2019, 05:54 PM Thread Starter
Thank you to all that offered suggestions.
The problem was the motor mounts.
The 2 front motor mounts and transmission mount were replaced and the vibration is gone.
andy_1100 likes this.
my2ndmb is offline
