Fuel rail bolts torque - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-21-2019, 12:00 AM Thread Starter
Photodude's Avatar
Date registered: Apr 2013
Vehicle: 2004 E320, 2000 SL500, 1987 300TD
Quoted: 161 Post(s)
Hi, I'm replacing fuel injectors on my friend's 97 C280 (M104.941) I can't find torque specs for the 5 bolts holding fuel rail. There is nothing in WIS on this, I only see 25 Nm for intake manifold bolts.
Is it safe to assume that fuel rail bolts would be the same 25 Nm? I don't want to over-torque and possibly bust manifold gasket.
Andrew
Photodude is offline
post #2 of 4 (permalink) Old 05-21-2019, 05:57 AM
Date registered: Jul 2010
Vehicle: 1995 C220
Quoted: 208 Post(s)
If memory serves me well, those are just 6mm bolt. 25 nm would be way too much for that size. Half of that, or about 12 nm should be about right.
georgebuhr is online now
post #3 of 4 (permalink) Old 05-21-2019, 10:16 AM Thread Starter
Photodude's Avatar
Quoted: 161 Post(s)
These are M8 bolts with 6mm allen head. I had to use 7mm star shaped bolt extractor to get some of them out. I think I'll put back hex head bolts instead for easier access.
I'm not familiar with this engine but it looks like fuel rail bolts are part of intake manifold bolt pattern… which is why I don't want to over or under-torque them.
Andrew
post #4 of 4 (permalink) Old 05-22-2019, 06:01 AM
Vehicle: 1995 C220
Quoted: 208 Post(s)
If they are 8mm, then 25 should be ok, although a little strong. The charts say 23 nm.
2005 E320 CDI - Code P0193 - Fuel Rail Pressure Sensor wwwerrrt W211 E-Class 22 06-08-2016 07:56 PM
Fuel lines samosali W140 S-Class 78 02-26-2015 02:50 AM
Fuel pumps Real1shepherd W124 E,CE,D,TD Class 56 06-29-2014 06:03 PM
We Need A Permanent Sticky for Error Codes Hary Gahtoe C208/A208 CLK-Class 22 01-22-2010 12:11 PM
OBDII Scanners and Simple Sensor Diagnostics AC_ML W163 M-Class 2 03-24-2008 10:11 AM
