Gas smell in engine oil filter - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 05-15-2019, 01:59 PM Thread Starter
Date registered: Dec 2017
Vehicle: 1994 , C220
Quoted: 5 Post(s)
Hi benzers
Last time i changed the engine oil at the shop i took the oil filter with me to check for engine health the filter was so clean, i do this from time to time just to check if there is a metal inside the filter or etc.. but anyway there was a gas smell in the filter 😕 ...
What causes the gas to mix with oil ?
ghazi197 is online now
post #2 of 6 (permalink) Old 05-15-2019, 10:19 PM
khomer2's Avatar
Date registered: Nov 2015
Vehicle: w163 02 ML500 W210 97 E50Amg w202 99 C230K w124 - need more space, time to build again
Quoted: 202 Post(s)
Have you recently replaced your rocker valve cover gaskets?
Have you removed the fuel line from the rail?
khomer2 is online now
post #3 of 6 (permalink) Old 05-16-2019, 02:24 AM Thread Starter
Quoted: 5 Post(s)
No... i am really confused , i am worried about the engine , they told me if gas mixed with engine oil its a big problem . i wanna know what to check ..
post #4 of 6 (permalink) Old 05-16-2019, 07:12 AM
khomer2's Avatar
Quoted: 202 Post(s)
What viscosity oil are you using?
How is your oil level consumption?
EDIT:
Also.... use the search engine...... "gas smell in oil" and start reading.
post #5 of 6 (permalink) Old 05-16-2019, 09:03 AM
Date registered: Jul 2010
Vehicle: 1995 C220
Quoted: 205 Post(s)
It could be pushing past the rings, meaning you might have a stuck piston ring, then when it hits the compression stroke, some of the mixture is getting past and going into the crank case. You could test for sure by doing either a leak down test or a compression test.
I think there are some additives you can put in the fuel and the oil that may help get the ring unstuck if that is the case. I will confess that I have not much experience in using them though, with the exception that sometimes I will use a little marvel mystery oil in my crankcase, and a little in the fuel tank if I suspect a problem. I have never seen it make a huge difference, but the extra lubrication can only help things, not hurt. Also I would note that if you have access to 91 octane that doesnt contain ethanol, you should definitely be doing most of your fill ups there vs running a gas with ethanol. The more ethanol, the more deposits left behind.
georgebuhr is offline
post #6 of 6 (permalink) Old 05-18-2019, 07:00 AM Thread Starter
Quoted: 5 Post(s)
Finally problem solved (leaking fuel injector) replaced all of them ... 👍
Online Resources GeeS General Mercedes-Benz 57 01-16-2019 02:51 PM
Key code for BOSCH Injection pumps imjustdave Unimog 20 04-05-2011 01:49 PM
Cam Oilers and Sludge Removal 97e420sweet W210 E-Class 14 01-14-2009 08:58 AM
Engine's History (G. Daimler & W. Maybach) Curacao General Mercedes-Benz 1 08-03-2006 03:37 AM
320 CDI vs 350 rubensans W164 M-Class 1 05-03-2005 03:36 PM
