RR Engine Mounts - 99 C280 - Page 3 - Mercedes-Benz Forum
post #21 of 39 (permalink) Old 04-17-2019, 09:28 PM Thread Starter
Date registered: Feb 2019
Vehicle: 1999 C280
Quoted: 4 Post(s)
ok Deplore, two quick questions even if they sound thick -
1) Did you need to move the compressor just to roll out and in the DS mount or even before to be able to loosen the top bolt of the mount?
2) Using the offset wrench, you recommend, did you use it from the top or bottom of the engine? Did you use multiple extensions in the tool's 3/8th drive?
Thank you immensely for your help!
sgoesbwo is offline
post #22 of 39 (permalink) Old 04-17-2019, 10:02 PM
SDS Guru
Deplore's Avatar
Date registered: Apr 2014
Vehicle: 1998 MB E300TD, 1997 MB E320
Quoted: 752 Post(s)
1. Yes, the AC compressor being moved out of the way is solely to move the MM in and out. It is not to loosen or tighten the bolt on the top.
2. I did it from the top, and I did use multiple extensions. Again, the point is to just break it loose, not use it to keep loosening it. Once you break it loose, then it's loose and can be unscrewed by fingers. You don't need a lot of room -- just 1-2" of ratcheting travel is all you need.
CheckEngine likes this.
--1998 MB E300TD 291k
--1997 MB E36 Frankenstein'd AMG 199k
--2011 Suzuki DL650 58k
--1997 MB E320 161k. SOLD...loved that stupid car.
--1997 MB C36 AMG 273k -- stripped and junked
Deplore is offline
post #23 of 39 (permalink) Old 04-19-2019, 11:05 AM
Date registered: Sep 2005
Vehicle: 1999 C280, 2000 C280, 2000 C230K,2011 C300
Quoted: 28 Post(s)
On my 2000 C280, there was no need to loosen AC compressor. Also did not do anything to suspension or the steering damper. The drivers side mount came out to the rear easily by manipulating the left front wheel. I'm guessing this method would work on the passenger side without having to remove the alternator but I already had it out. Top bolts are tricky and are done from below. Stubby wrench works well here and as I mentioned, put the box end of wrench on the bolt and then use a pry bar against something solid and the notch of the open end of the stubby.
Re: the bushings around the alternator. I am sure these bushings are there for a reason but they sure made it difficult to get the alternator back in. In other applications the bushings are like locator pins and allow you to locate something heavy, like an alternator, and hold it while you get the bolts in.
glenmore
1999, 2000 C280
2000 C230K
2011 C300
glenmore is offline
post #24 of 39 (permalink) Old 04-19-2019, 12:42 PM Thread Starter
Vehicle: 1999 C280
Quoted: 4 Post(s)
Thanks so much for getting back glenmore!
Yeah from all that I have read so far, I will move the compressor and/or the alternator only if I need to. Your 2000 C280 is a M112 like my 1999 C280 so let's see how everything works out..
I do have both the stubby box and stubby ratcheting box wrenches. I also have the Blaster penetrating oil spray if needed and planning on getting this offset wrench - https://www.ebay.com/i/123718137161?chn=ps. Do you think a 3/8th extension can be used from below to drive the offset wrench on the top bolts of both the mounts?
You all have been very helpful on this board, so a huge thanks to all!
sgoesbwo is offline
post #25 of 39 (permalink) Old 04-19-2019, 01:20 PM
Quoted: 28 Post(s)
That looks like a decent tool and should come in handy but you should be able to do it with just the stubby combo wrench and pry bar. Looks like you would use a 3/8" extension and breaker bar from below.
glenmore
1999, 2000 C280
2000 C230K
2011 C300
glenmore is offline
post #26 of 39 (permalink) Old 04-19-2019, 02:02 PM Thread Starter
Vehicle: 1999 C280
Quoted: 4 Post(s)
Thanks guys,
I will get back if I run into problems while doing the job and for sure after I get it done. One thing I will try to get insight on (hopefully!) is why WIS proc is telling us to undo some drag link arms or is it some misprint...
Great weekend guys!
sgoesbwo is offline
post #27 of 39 (permalink) Old 04-19-2019, 06:00 PM
CheckEngine's Avatar
Date registered: Dec 2017
Vehicle: 1999 C280 (sport), also 2001 SLK230
Location: Redding, CA (for now) Boston, MA, & Mexico City
Quoted: 13 Post(s)
@sogoesbwo
I have the same car as you, '99 C280, and one of these days I'm going to replace the engine mounts. So I'm very interested in your experience doing it. Please be sure to follow up here once you've done the job.
Cheers and good luck!
Kim G
Redding, CA
Where I should just get off my ass and do it, haha.
P.S. "Fupabox" on YouTube has a lot of good videos for various repairs on the W202, and Ken Bergsma of MercedesSource is also a good resource.
CheckEngine is offline
post #28 of 39 (permalink) Old 05-16-2019, 02:26 PM Thread Starter
Vehicle: 1999 C280
Quoted: 4 Post(s)
Hi Folks!
Replaced the Engine and trans mounts a week ago and all the vibration is gone.
The only vibration (if its vibration) that I now feel is in neutral or parking gear when the rpm goes up to right around 750, where as in brake mode while in reverse or drive gear it is right around 550 and there is no vibration at all. I'll keep a watch and start a new thread for it. My next project for this car is replacing the AC compressor for which I will start a new thread after doing some research.
Anyway let me share with you how the mounts were replaced in my car -
1) Got hold of the MB replacement instruction for my car. Made sure I understood every word in the one-page instruction set plus some related instructions.
2) Asked for help on this wonderful forum where as you can see so many jumped in to help and encourage me.
3) Inspected the car from the top and bottom - several times until everything made sense to me.
4) Decided not to mess with the drag link per MB instruction, as that may entail additional cost of alignment at the shop. Instead will try wiggling the mounts out and in first and if that doesn't work, will move the AC compressor and/or the alternator. Also decided 2 men best for the job.
5) Got the 16mm Mercedes offset wrench (like El Paso Tools on ebay), 3/8th long and short ratchet extensions, a low profile 16mm or 5/8" hex socket head set with 3/8th drive (like OEM Tools), a thin profile 3/8th ratchet driver (like Harbor Freight 67993) for the MM top bolts. Wrench and sockets as needed for bottom bolts, trans mount bolts, the AC compressor, alternator, ground wire nuts, battery, washer reservoir, fan belt tensioner, protective glasses, plenty of rags and plastic containers to catch the hydraulic oil if it spills. Of course floor jack, jack stands and chocks.
6) Parts - got Mercedes genuine online from www.mercedesbenzpartscenter.com but others can be cheaper sometimes like www.mbpartsworld.com. Don't forget to check autohausaz and others too, you never know who's running a special! Genuine is made by BOGE and very good OEM is made by Lemforder. Both are owned by ZF Auto. My old ones don't have any manuf marking, just Merc Star and part number as part of the rubber mold. The old trans mount has no markings, the new one also does not have any manuf marking just part # and Made In India label. Depending on the condition of your car, you may want to keep new nuts and bolts with you just in case. Getting it from the dealership is very expensive about $60, so I went to the dealership with calipers, measured all of em, took pics especially the manuf symbol on em and spent days trying to get exact match from places like Metric & Multistandard, Fastenal, local manufs. I couldn't find a match for the lower bolts. However, I ended up not needing any, my original bolts were all like new. So I returned all of 'em after the job.
7) Jacked up the car. Did the ds first. Unbolted and got the washer reservoir out of the way. Loosened the top bolt first with the Mercedes 16mm offset tool and ratchet extension from the top. Two 1" turns is all it takes, then you can unscrew with your fingers. Then raised the engine and unbolted the bottom bolt. Noticed hydraulic fluid, so wrapped it in a rag. When wiggling out failed, unbolted and moved AC compressor and ground wire, which allowed the mount to be brought more to the front and then was picked up from the top by the other guy. The new one went in the same way but the engine had to be raised a bit more. Hand tightened the bolt below, lowered the engine slightly, made sure the notch and the tooth were in line and dropped the engine slowly all the way. Hand tightened the top bolt from the top, then used the low profile 16mm socket head with thin profile 3/8th driver from below to approximate the 55Nm torque. This side took 2 hrs and I drove it about 20 miles to see if it made any difference but no difference.
8) Next day, we did the ps. Jacked up the car again and took off the air filter box and attached connectors. Saw no space to position the ratchet extension. So disconnected battery -ve and unbolted the two bolts on the alternator, top and bottom, eased it out of the hold and moved it to the front. This allowed me to angle my drive extension to loosen the top bolt in two short sweeps and then unscrewed it by hand. I noticed the hydraulic fluid on this. Raised the engine, loosened the bottom bolt, unscrewed it, and immediately wrapped it in a rag. This one came out easily. The new one went in with the same way, followed the same process as for the ds, and then bolted back the alternator. BTW, moving the alternator and putting it back on was no problem at all on my car. It was easier and a lot quicker than the AC compressor. This side took 1 hr.
9) Immediately after this, we did the trans mount. The one on the car was still in perfect condition, but I replaced it with the new one. This one was quick and easy and took about 15 minutes.
10) Last, we cleaned up and reconnected the battery, reset the radio code and normalized the power windows and sunroof and that was the end. Took it for a spin and that's when noticed the immediate huge improvement. I recommend anybody experiencing vibration, do the mount test and check if the mounts are leaking hydraulic fluid and replace the mounts asap. Just to let you know, my old mounts failed the test, were leaking, but still are in great shape! In terms of difficulty, I would rate it 2.5 out of 10 if at all and not to much fiddling around, at least not in my 99 C280.
Thanks a lot guys!
Deplore likes this.
sgoesbwo is offline
post #29 of 39 (permalink) Old 05-19-2019, 08:53 PM
Quoted: 28 Post(s)
Awesome! Paid for all your tools and then some!
glenmore
1999, 2000 C280
2000 C230K
2011 C300
glenmore is offline
post #30 of 39 (permalink) Old 05-20-2019, 10:00 AM Thread Starter
Vehicle: 1999 C280
Quoted: 4 Post(s)
Hi glenmore,
talking about tools - its amazing how inexpensively you can get what you need with awesome deals running all the time! For this job, I ended up buying the Harbor Freight slim prof ratchet and the Baum Tools offset wrench. Had everything else and borrowed the 3/8th long extension.
I am repairing the power seat relay now and saw you in that thread, so will post more about it there. After that -
1) rr the AC Compressor,
2) repair the sagging headliner or best rr if I can get hold of a new one from Mercedes around $299,
3) what's making the rubbing noise on the ps front tire in reverse gear when wheel is turned all the way to the left and sometimes when I am going back straight,
4) intermittent very low clicking noise on the ps when I am at a stop,
5) my radio that goes high on its own, changes station when I try to change volume and all kind of random stuff,
6) how to get my pickup back to when my car was newer,
7) and who knows what else may show up
Cheers!
sgoesbwo is offline
2005 CDI Motor Mounts kitesurfer805 W211 E-Class 7 04-27-2018 02:05 PM
Injection Pump fuel adjustment for the MW and M pumps, engine tuning and maintenance Forcedinduction W123 E,CE,D,CD,TD,TE Class 5 11-28-2017 01:19 AM
w114 220D with 300TD engine Keevo114 Vintage Mercedes-Benz 1 01-21-2010 08:46 AM
Intermittent engine stall causes? 500SEL drcvd W140 S-Class 12 12-04-2009 09:26 AM
Cam Oilers and Sludge Removal 97e420sweet W210 E-Class 14 01-14-2009 08:58 AM
