Need help... C280 m104 722.4 no foward or reverse gears - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 04-04-2019, 01:12 AM Thread Starter
Date registered: Apr 2019
Hi... I have a 1996 c280 m104 with a 722.4 auto box.
The issue is... At first, it was accelerating very slow, as if in 3rd gear... Now all of a sudden, there is no gears if i put in drive or reverse... Just no movement. We have put in new atf.... And still nothing... What could the issue be?
Flospeed is offline
post #2 of 8 (permalink) Old 04-04-2019, 11:42 AM
khomer2's Avatar
Date registered: Nov 2015
Vehicle: w163 02 ML500 W210 97 E50Amg w202 99 C230K w124 - need more space, time to build again
Quoted: 269 Post(s)
Welcome Flospeed,
Scan for codes and post.
Also, please update your user cp info.
Name:	user cp info benzworld.jpg
khomer2 is online now
post #3 of 8 (permalink) Old 04-04-2019, 09:59 PM
PlaneCrazy's Avatar
Date registered: Oct 2010
Vehicle: '86 W123 200, OM617 non-turbo, bastard 5-speed; '95 W202 C250 Diesel, OM605 non-turbo, 5-spd man
Quoted: 495 Post(s)
I only drive manuals, but am I wrong to guess that 722.4 is still a vacuum-operated auto? Either way, try asking on the W124 forum as well.
W202 C250 Diesel, OM605 NA engine, 5-speed manual
1986 200, OM617 NA engine, 5-speed manual, rev counter
Donkey, not gone, never forgotten...
PlaneCrazy - it's more than a name, it's a life choice!
QUOTES FROM CONSTERNATIUS:
"Inside every small problem is a big problem screaming to get out."
PlaneCrazy is offline
post #4 of 8 (permalink) Old 04-06-2019, 02:35 PM
MB-W202's Avatar
Date registered: May 2010
Vehicle: 1995 C280 (165K mi)
Quoted: 128 Post(s)
shifter...do you feel it engage and then no movement or is it a dead stick? how many miles? check the linkage under the gear box.
MB-W202 is offline
post #5 of 8 (permalink) Old 04-06-2019, 10:09 PM Thread Starter
When i jack the rear up.... And the put it in drive...no movement... When putting into any gear... No noises or anything... Just dead
Flospeed is offline
post #6 of 8 (permalink) Old 04-10-2019, 04:03 PM
Date registered: Jun 2014
Vehicle: 1997 C280
Quoted: 18 Post(s)
Vacuum lines that control the auto broken/disconnected/leaking?
Mortalomena is offline
post #7 of 8 (permalink) Old 04-23-2019, 06:26 AM
Date registered: Aug 2014
Vehicle: 1995 C280 1997 S320
Quoted: 14 Post(s)
First of all check atf level. I assume you know that atf level is checked with running engine...
Next id check the shifter linkage.. Get under the car make sure it didn't fall off..
722.4xx is a hydraulic transmission.. There are no electrical valves in it, so the issue is in the transmission itself.
As you describe that the car was slow to accellerate.. Did you fell it slipping where engine rpm go up wirhout any speed change?
If you lost vacuum conbections the car will still drive.. Will be rough shifting but will drive..
Sent from my LG-H873 using Tapatalk
you can watch all my MB repair videos on
andy_1100 is offline
post #8 of 8 (permalink) Old 06-18-2019, 10:31 PM
Date registered: Mar 2010
Vehicle: 1990 190e 2.6l Calif. auto 1987 Ford F150 4.9L Calif. man 4OD 4X4 2013 Suzuki C50 Crusier
Quoted: 14 Post(s)
So what was the out come ??
zpa001 is offline
FS: Wiring harness for W202s with M104 engine (C280 | C36) flipnautics W202 C-Class 6 07-26-2012 10:39 AM
Transmission doesn't shift gears - 1st gear working only and Reverse mercedesc230 W202 C-Class 4 03-01-2012 03:39 PM
91 300d 2.5 turbo - Reverse but no forward gears zwe66 W124 E,CE,D,TD Class 2 12-31-2011 08:43 PM
2 or 4 speed crawler gears on the 404. dxmedia Unimog 14 12-30-2011 07:41 AM
94 C280 tranny won't go in reverse Serge Trullet W202 C-Class 5 04-26-2007 06:59 AM
