C280 idle speed - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 09-20-2018, 06:14 PM Thread Starter
Date registered: Jun 2010
Vehicle: 1998 C280
Quoted: 4 Post(s)
C280 idle speed
My 1998 C280 idles at about 700 rpm in neutral but drops to about 500 rpm when put in gear. This results in some vibration. Should the idle speed be dropping this low?
fatherfixit is offline
post #2 of 8 (permalink) Old 09-21-2018, 10:51 PM
khomer2's Avatar
Date registered: Nov 2015
Vehicle: w163 02 ML500 W210 97 E50Amg w202 99 C230K w124 - need more space, time to build again
Quoted: 263 Post(s)
Our 99 c230K drops similarly, but no vibration. Very quiet and smooth.
Have you check where the vibration is coming from?
Perhaps engine and tranny mounts?
khomer2 is online now
post #3 of 8 (permalink) Old 09-22-2018, 05:44 AM
duh_vinci's Avatar
Date registered: Feb 2015
Vehicle: 1995 SL320, 1995 SL500 ("Red Devil " project), 1998 C280, 2004 E500 4matic
Quoted: 252 Post(s)
These RPMs under load are normal, vibration is certainly not...
Originally Posted by khomer2 View Post
...Perhaps engine and tranny mounts?
I have to agree, motor mounts would be the first thing I would inspect... This video, about 0:40 sec into it would give you a good visual of what the failing motor mounts "look like" https://www.youtube.com/watch?time_c...&v=6HrRLjoPark
Regards,
D
duh_vinci is offline
post #4 of 8 (permalink) Old 09-22-2018, 08:48 AM Thread Starter
Vehicle: 1998 C280
Quoted: 4 Post(s)
The motor mounts are less than two years old and have about 25,000 miles on them. Its just a slight vibration due to low engine speed. The thing is, I don't remember the idle dropping this low when the car was newer, and I wondered if the computer was supposed to bump up the idle to keep it in the 700-800 range to compensate for load.
post #5 of 8 (permalink) Old 09-22-2018, 09:11 AM
khomer2's Avatar
Quoted: 263 Post(s)
Our w202 kompressor rpms dropped and ran very smoothly after:
1) maf cleaning with CRC maf cleaner
2) bottle of berryman (into both the vacuum intake and throttle intake) - to cleanup what the previous owner's minimal maintenance routine
(got some misfiring and an engine light after this which is normal...)
3) air filter change (did not do an oil change yet as the color was good)
4) oil separator and line checks
5) spark plug checks
6) egr vacuum check (diaphram working ok) - did not open up to check the lines to see how clogged up they may be - too lazy.
Have you scanned for any codes?
post #6 of 8 (permalink) Old 09-22-2018, 09:18 AM
khomer2's Avatar
Quoted: 263 Post(s)
Regards,
D
I agree, but, honestly, Iv'e dealt with other cars where the motors mounts had failed and the engine ran fine with minimal vibration/shaking. My neighbor, a bodyman, was the one that picked up one of our minivans ONLY after taking a closer look and noticed a slight "clunk" when the tranny engaged into drive or reverse. Every car is different and I see your point.
Doesnt hurt to still check them visual, that's why I asked.
post #7 of 8 (permalink) Old 09-22-2018, 03:56 PM
khomer2's Avatar
Quoted: 263 Post(s)
some more nfo that ay assist you.
https://www.benzworld.org/forums/w20...-rpm-drop.html
post #8 of 8 (permalink) Old 09-23-2018, 06:40 AM
duh_vinci's Avatar
Quoted: 252 Post(s)
Originally Posted by fatherfixit View Post
The motor mounts are less than two years old and have about 25,000 miles on them...
Then I would stick with the list of khomer2 suggestions/steps. As at 500-600 rpm range with D or R engaged, one should have no vibrations.
Regards,
D
