Glove compartment door refuses to close - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 08-07-2009, 06:58 AM Thread Starter
coenc's Avatar
Date registered: Aug 2009
Vehicle: W202 C180 Sport 1996
Post Glove compartment door refuses to close
After taking out and cleaning the cabin air filter under the glove comparment, which all went fine, suddenly the door of the glove compartment will not close anymore. It always worked fine before.
I suspect there is a cable connected to the central locking mechanism that has snapped off or got stuck.
Anybody ever experienced this or knows how to fix it?
coenc is offline
post #2 of 10 (permalink) Old 08-07-2009, 07:15 AM
davo's Avatar
Date registered: Sep 2008
Vehicle: '96 C220 n/a diesel
your glovebox is nothing to do with your cental locking tho, try adjusting the 2 rubber stoppers at the top left and right corners, chances are their 2 far out, i had that when i took the glovebox out to route my ipod into it, either that or your lock's shot
davo is offline
post #3 of 10 (permalink) Old 08-07-2009, 08:04 AM Thread Starter
coenc's Avatar
The rubber stoppers should be fine, because I didn't touch them at all... It all worked fine. From one moment to the other it stopped locking.
Maybe the actual lock (at the top middle of the cover) is shut in a locked position and doesn't release anymore.
I see a little metal click thing moving inside the lock when I pull the handle that opens the glovecompartment, but it only move a millimeter or 2.
The lock itself can be pressed in about 5 mm and springs back again.
coenc is offline
post #4 of 10 (permalink) Old 08-07-2009, 08:28 AM
davo's Avatar
are u sure u pushed the glovebox all the way in? i'll have a look at mine in a while, and let u know tho, is it possible thet uv locked it and thats why it wont close? just a thought
davo is offline
post #5 of 10 (permalink) Old 08-07-2009, 09:59 AM Thread Starter
coenc's Avatar
I pushed it hard enough, it's not locked either....
I took a closeup of the lock:
http://85.144.203.14/lock1.jpg and http://85.144.203.14/lock2.jpg
Can you see if it looks the same with you?
Always nice to be able to compare things with the 'old situation'
Thanks davo!
coenc is offline
post #6 of 10 (permalink) Old 08-07-2009, 02:27 PM
xvvvz's Avatar
Date registered: Sep 2006
Vehicle: '99 2.3L Kompressor
If the lock mechanism is working fine, the next thing is that these get misaligned over time and then the latch will not work correctly. I believe there are some screws that will let you adjust the lock's position or maybe you adjust the position of the hook/catch instead of the lock. It has been too long for me to remember for sure.
xvvvz is offline
post #7 of 10 (permalink) Old 08-09-2009, 11:32 AM Thread Starter
coenc's Avatar
Problem solved. I screwed open the glove compartment door just enough to pry it open a little bit and noticed that the lock mechanism inside the door came loose from 1 of it's 2 retainers.
In the picture http://85.144.203.14/lock2.jpg I indicated in red the free play that was not supposed to be there. As they are plastic parts, a drop of plastic glue should do the job.
I noticed that both hinges can be easily aligned when you pull out the 2 square plastic covers with the tip of a screwdriver. Inserting the little blocks back into position will freeze the alignment of the door.
coenc is offline
post #8 of 10 (permalink) Old 12-04-2010, 10:41 PM
Date registered: Jun 2005
i think i'm having the same problem.
i wish i could see those pictures, but the links don't seem to work for me.
hangup is offline
post #9 of 10 (permalink) Old 12-05-2010, 09:39 AM
acousticplayerjb's Avatar
Date registered: Mar 2010
Vehicle: 2000 c230 Kompressor (Totalled 5/2012)
I used to have a similar problem. It turns out that a piece of plastic inside of the door had snapped. I opened it up and was able to create sort-of a "splint" for it. It's been working fine ever since. I don't have pictures unfortunately. Open up the door and look around very carefully. The locking mechanism is very picky and even a slight misalignment can prevent it from working properly.
acousticplayerjb is offline
post #10 of 10 (permalink) Old 10-04-2014, 05:07 AM
sulaco's Avatar
Date registered: Apr 2010
Vehicle: 1999 C43 AMG, 1998 C43 AMG
Quoted: 10 Post(s)
thread revival!
as w202's age this becomes a bigger and bigger problem. bumping this thread for brevity.
having this issue with both my C43's and it's driving me insane. The one I drove today keeps dropping open every time I hit a bump, but nothing is broken or misaligned as far as I can tell. UGH.
1999 C43 AMG 744-Silver - Mine
1998 C43 AMG 040-Black - Wife's
1980 240d - project - non-EGR
sulaco is offline
Glove Compartment door loose GogglesPisano764 W123 E,CE,D,CD,TD,TE Class 7 04-06-2009 09:08 PM
Question about the glove compartment door gafitanu W211 E-Class 1 12-17-2007 11:22 AM
W124 Glove Compartment Door Marinero For Sale/Wanted/Trade/Giveaway 1 03-20-2007 04:46 AM
Glove Compartment stephenb W126 S,SE,SEC,SEL,SD,SDL Class 1 07-23-2004 08:18 AM
Rattle in glove compartment door? Bayer W163 M-Class 1 02-21-2003 10:46 PM
