99 c230 fuse guide - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 01-10-2007, 10:12 PM Thread Starter
Date registered: Dec 2006
Vehicle: 2008 c300
Question 99 c230 fuse guide
I just got my 99 c230 last month and found out that fuse #4 located inside the trunk is missing. i know it is for the rear defroster but not sure what amp bec the guide insert is missing too!. is there anyone who can give me the fuse specs? or maybe the specs for all the fuses. tks!
junnc is offline
post #2 of 9 (permalink) Old 01-11-2007, 08:06 AM
xvvvz's Avatar
Date registered: Sep 2006
Vehicle: '99 2.3L Kompressor
I don't have access to my manual right now or I would try to look it up for you. Why don't you call the Mercedes help line 1 800 For Mercedes or whatever it is.
xvvvz is offline
post #3 of 9 (permalink) Old 01-11-2007, 01:56 PM Thread Starter
Vehicle: 2008 c300
i already called to the dealer to buy the fuse but they don't know too what amp. It's not in their system (parts). So it will be a big help if you can find it for me. many thanks.
junnc is offline
post #4 of 9 (permalink) Old 01-14-2007, 10:03 AM
benzpimp's Avatar
Date registered: Oct 2005
Vehicle: 2009 C300
here is the fuse diagram for a 1999 c230 which is under the hood.
Name:	Fuse Diagram.jpg
benzpimp is offline
post #5 of 9 (permalink) Old 01-14-2007, 10:14 PM Thread Starter
Vehicle: 2008 c300
thanks for the diagram but what i really need is the one located inside the trunk, spare tire compartment. If you'll get a chance pls post/attach the copy. tks!
junnc is offline
post #6 of 9 (permalink) Old 01-14-2007, 11:48 PM
Date registered: Mar 2006
Vehicle: 1996 Silver C36
It's not a diagram. It's a two tables! benzpimp has given you all the information you need.
If you look at the first table for"Heated rear window" you will see fuses 41,2*,4*.
If you look at the legend Identification = "*" you will see "corresponding fuse in the trunk".
If you look at the second table 2* and 4* you will see "fuse rating" is 5A and "color" is beige.
Welcome to benzworld!
OzC36 is offline
post #7 of 9 (permalink) Old 01-15-2007, 11:52 PM Thread Starter
Vehicle: 2008 c300
OzC36,
Yes, fuses 41,2*, & 4* are for the heated rear window but bec fuse 41 uses 5A, it doesn't mean fuses 2* & 4* will use the same rating. NO! If you'll try to look again on those diagrams (what i know, diagrams are also known as tables or charts) you will not find any info about 2* & 4*. And as you mentioned, the legend says "Identification "*" = corresponding fuse in the trunk ... Note: Observe correct amperage! Further fuses are located in the trunk" So, I think my real problem is that my fuse box diagram that is located inside my trunk is MISSING! as well as the fuse 4*. That's why I have no any idea what fuse to use. If you'll use 5A for 2* 4*, it will just get burned once you turn on the defroster. I believe the rating should be higher than 15A, maybe 30 or 40? Help!
junnc is offline
post #8 of 9 (permalink) Old 01-30-2007, 02:37 PM
benzpimp's Avatar
Vehicle: 2009 C300
here you guys go
Name:	Trunk Fuse Diagram.jpg
benzpimp is offline
post #9 of 9 (permalink) Old 02-14-2007, 04:34 PM Thread Starter
Vehicle: 2008 c300
thank you benzpimp.
by the way i just lowered my car with eibach pro kit springs now i need the camber alignment kit. anybody knows where can i get 'em?
junnc is offline
2000 ML 320 Lighter Fuse Blown | Which fuse do I replace? Patkar g_patkar W163 M-Class 12 05-21-2016 07:44 PM
Adding fuse to dashboard fuse block fgwinn W211 E-Class 6 07-06-2012 05:27 AM
Replaced Fuse -- Need Radio Code C230 (1997) raleighbob Audio & Telematics Forum 0 10-29-2006 09:36 AM
unplug fuse for daytime running lights on c230 heuer007 W203 C-Class 2 10-09-2006 06:31 PM
fuse guide??? Dolphin27 R170 SLK-Class 1 02-10-2006 06:29 AM
