722.409 trans gaskets - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-18-2019, 10:25 PM Thread Starter
Date registered: Mar 2010
Vehicle: 1990 190e 2.6l Calif. auto 1987 Ford F150 4.9L Calif. man 4OD 4X4 2013 Suzuki C50 Crusier
Quoted: 14 Post(s)
I am going to order a trans gasket kit for my 1990 190e 2.6L. 722.409 serial #841351. I see when I try to order, there is a split on the gasket set ( thur #620296 ). My serial # is above that as you can see. So looks like there is two different sets with some different seals or "O" rings or something. But on the websites it is not showing a split for the (valve body plate gasket). In my trans book it is showing a ( Early Regulator Case ) and a
( 190 722.4 Case ). So on the 190 722.4 case is the valve body gasket the same to be used for both serial # kits. And if someone can clear up what is the different in the seals and "O" ring stuff sets.
zpa001 is offline
post #2 of 3 (permalink) Old 06-20-2019, 12:20 PM
Date registered: Jul 2018
Vehicle: 1990 300SE
Quoted: 37 Post(s)
part number 2012704801
From transmission serial # 620297
christuna is online now
post #3 of 3 (permalink) Old 06-20-2019, 01:59 PM Thread Starter
Quoted: 14 Post(s)
Thank You
zpa001 is offline
