W124 parts compatibility for W201 - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-22-2019, 03:47 AM Thread Starter
Date registered: May 2019
Does anyone now if an exhaust system from the same year W124 would be compatible with the same fuel type W201?
Thanks.
190Irl is offline
post #2 of 4 (permalink) Old 05-22-2019, 12:30 PM
partnumber187's Avatar
Date registered: Jun 2016
Vehicle: Mercedes-Benz
Quoted: 244 Post(s)
You could maybe use the can if you wanted to cut it out and weld it in, but the length, routing, and hanger locations are all different if you want to install it as is.
Proceed with caution. >>>
#dontdealwithkahlil
partnumber187 is offline
post #3 of 4 (permalink) Old 05-22-2019, 07:49 PM
Date registered: Dec 2012
Vehicle: 89 190E2.6- 5-speed Manual, 95 E320 Sportsline-sold, 2001 E320 4matic Wagon-sold
Quoted: 524 Post(s)
Send a message via Skype™ to dolucasi
As PN187 pointed out, you maybe able to make it somewhat work by cutting/bending/stretching/etc. but remember that even the same model year 201 with M102 vs M103 engine exhausts are different.
Heck in my opinion some aftermarket exhaust parts meant for the same year is not a prefect fit because of the tight tolerances to the body/axle parts/etc.
dolucasi is offline
post #4 of 4 (permalink) Old 05-23-2019, 11:54 AM
w201-16's Avatar
Date registered: Sep 2012
Quoted: 21 Post(s)
The front part fits.
The middle part is on the opposite side.
You can use it if you cut and weld it "upside-down".
Been there done that.
Sent fra min H8324 via Tapatalk
w201-16 is offline
