1992 W201 2.6 - Instrument Cluster - Mystery Wire? - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 05-19-2019, 03:19 PM Thread Starter
Date registered: Dec 2007
Vehicle: 1995 E420 / 2009 C350 / 2009 C350 / 1992 500SEL (sons) / 1992 190e-2.6 (wife's)
Quoted: 10 Post(s)
Hi All,
Attempted removal of the instrument cluster in this 1992 2.6 so that I can repaint the needles and repair the outside air temp display - but I have come across a mystery "wire" without any sort-of connector that I can see.
For the outside air temp display, there are two connectors - a 3-pin and a 2-pin. But in this car, there is another black-sheathed cable of some sort that comes out of the area where the temperature display is, and departs down under the dash out of site without any kind of connector visible to be able to disconnect it. The 1985 that I scrounged some parts from this week did NOT have this cable.
Do any of you know where it goes? I have not yet removed the under-dash knee-bolster - do you think there is a connector hiding down there somewhere?
Thanks in advance!
~Bryan
bwcole is offline
post #2 of 8 (permalink) Old 05-19-2019, 04:38 PM
Date registered: Jul 2010
Vehicle: '85 300D Turbo, '91 420SEL, '92 190E 2.6, '09 C350, '12 E63 Wagon
Quoted: 594 Post(s)
Would be very helpful if you can post a picture. Might be aftermarket...
jzchen is offline
post #3 of 8 (permalink) Old 05-20-2019, 12:29 PM Thread Starter
Quoted: 10 Post(s)
Good idea jzchen,
Attached is a photo. You can see the two expected plugs, one is the 2-pin, and the other is the 3-pin, but then emanating is a fairly factory-looking additional black-sheathed wire near where the tip o my thumb is placed in the photo.
Thanks much,
~Bryan
bwcole is offline
post #4 of 8 (permalink) Old 05-20-2019, 02:34 PM
355190E26's Avatar
Date registered: Oct 2007
Vehicle: 89 190E 2.6 x2
Quoted: 93 Post(s)
If I recall correctly, I think that's a vehicle speed sensor. Last time I pulled my cluster, I just wound up cutting the wire and then spliced in some quick disconnects when I re-installed it.
355190E26 is offline
post #5 of 8 (permalink) Old 05-20-2019, 05:11 PM
Date registered: Dec 2012
Vehicle: 89 190E2.6- 5-speed Manual, 95 E320 Sportsline-sold, 2001 E320 4matic Wagon-sold
Quoted: 547 Post(s)
Send a message via Skype™ to dolucasi
You mean like for the hall effect sensor 355? If so I would say it is rather important.
dolucasi is online now
post #6 of 8 (permalink) Old 05-23-2019, 06:33 AM
slk230red's Avatar
Date registered: Mar 2004
Vehicle: '01 SLK230,'93 190E 2.3, 1971 LS5 Corvette Convertible
Quoted: 77 Post(s)
You don't hear that term too often.
dolucasi likes this.
slk230red is offline
post #7 of 8 (permalink) Old 05-23-2019, 11:51 AM
w201-16's Avatar
Date registered: Sep 2012
Quoted: 22 Post(s)
Two pin wire is the tempsensor
Three pin wire is ground, ignition and light
One wire is speedsensor
Sent fra min H8324 via Tapatalk
w201-16 is offline
post #8 of 8 (permalink) Old 05-28-2019, 10:46 PM
SEC 560's Avatar
Date registered: Oct 2012
Vehicle: 93 190e 2.6
Quoted: 38 Post(s)
If you remove the knee panel and look from underneath you will find where it is plugged into I had some trouble finding it when I was doing my heater core.
SEC 560 is offline
1992 500 SL instrument cluster and power top issues roachie R129 SL-Class 1 04-08-2019 11:20 AM
instrument cluster stopped working now trouble code P0700 Tyrone Williams W163 M-Class 23 08-23-2016 09:50 PM
Instrument cluster and BBA Remanufacturing 3timesMBZ R129 SL-Class 2 09-16-2014 01:51 AM
Mystery Instrument Cluster Display Icon clmsd W212 E-Class 15 06-20-2012 10:59 AM
FS: W201 190e Class Instrument Cluster Nfsjunkie91 For Sale/Wanted/Trade/Giveaway 0 05-03-2011 08:48 PM
