NO START ? - Page 2 - Mercedes-Benz Forum
post #11 of 40 (permalink) Old 05-12-2019, 10:06 AM
Date registered: Jul 2018
Vehicle: 1990 300SE
Quoted: 18 Post(s)
sorry to hear that so it quit while driving? if so then check your main engine ground because that could give you both a no start and stalling. keep us posted
christuna is offline
post #12 of 40 (permalink) Old 05-12-2019, 10:10 AM Thread Starter
Date registered: Nov 2018
Vehicle: 1990 Mercedes Benz 190E 2.6
Quoted: 2 Post(s)
My feeling is just that. It may be simply a bad ground or a dead battery since all the symptoms seem to indicate that. I will post my findings once I drag the old gal home. I wish my old man was around at times like this.
LauraS is offline
post #13 of 40 (permalink) Old 05-12-2019, 10:11 AM
Vehicle: 1990 300SE
Quoted: 18 Post(s)
easy way to check your ground is to run a wire from engine block to the negative on the battery
post #14 of 40 (permalink) Old 05-12-2019, 12:01 PM Thread Starter
Quoted: 2 Post(s)
Well car I sold home and it started without a boost but when it arrived home it wouldn't start again. I checked the battery and it was dead. The charging light does come on when the ignition is on so maybe I missed it if the alternator is not working. Once I get the battery charged I will check the charge voltage and clean all the terminals. Sorry for making such a fuss about a dead battery.
LauraS is offline
post #15 of 40 (permalink) Old 05-12-2019, 04:24 PM
Supreme Sandwich
Josh's Avatar
Date registered: Aug 2010
Vehicle: '84 Euro 500SE, '85 Euro 2.3-16, '51 Euro 170S, '97 Jeep Wrangler Sport, '15 G63 AMG
Location: San Antonio, Texas/Gulf Breeze, Florida/Neustadt a.d. Aisch, Deutschland
Quoted: 697 Post(s)
An aging battery will throw you for a loop every time.
I had a similar issue and neglected to remember my battery was already 8 years old! Well beyond their normal life cycle, especially here in Texas.
'85 Euro 190E 2.3-16
'84 Euro 500SE
'51 Euro 170S
'15 G63 AMG
'98 Dodge Durango SLT+ 5.9L Magnum V8
'96 Ford F350 7.3 PSD
~Josh
Josh is online now
post #16 of 40 (permalink) Old 05-12-2019, 05:55 PM Thread Starter
Quoted: 2 Post(s)
Josh, The battery is only two years old. Laura
LauraS is offline
post #17 of 40 (permalink) Old 05-12-2019, 06:27 PM
Supreme Sandwich
Josh's Avatar
Quoted: 697 Post(s)
Not uncommon for even a new battery to have a dead cell. It sometimes just happens.
'84 Euro 500SE
'51 Euro 170S
'15 G63 AMG
~Josh
Josh is online now
post #18 of 40 (permalink) Old 05-12-2019, 08:04 PM
CH4S Artist
Teutone's Avatar
Date registered: Sep 2004
Vehicle: 1985 500SEC, 1991 190E 2.6.
Quoted: 1752 Post(s)
When not starting in P, did you try in 'N' yet? If handbrake interferes, block the wheels if not on even ground.
Another thing to look out for are fully or partially 'corroded' ground cables (often woven or stranded) from the battery. You usually see a bit of white residue (an old on the road trick was to pour coca cola over the cable. The acid eats away tha corrosion, but it will look quite messy).
Before buying a new starter, check whether the voltage is within prescribed parameters. Frequently a new voltage regulator is the culprit and much cheaper.
The link to the Mercedes factory manual should be in the stickies on top.
Daimler Benz made different spec versions of same model/chassis cars for different parts of the world. So, to get the correct advice on an international forum, location can be important.
Please click 'User CP' and complete your profile with at least a general location.
Search the forum archive with your topic via the 'google special search' box on top, until you get used to the vB forum search.
Cheers
Teutone is offline
post #19 of 40 (permalink) Old 05-12-2019, 11:59 PM
Date registered: Dec 2012
Vehicle: 89 190E2.6- 5-speed Manual, 95 E320 Sportsline-sold, 2001 E320 4matic Wagon-sold
Quoted: 508 Post(s)
Send a message via Skype™ to dolucasi
If you are suspecting electrical system issues (battery/alternator/regulator/harness grounding/etc.) I would strongly advise buying a USB charger with a built in voltmeter and sticking it in the cigarette lighter at all times. Only a $10 investment and can save you hours of grief and diagnostics. Also if you start having aging components noted above you will see signs well in advance. It even flashes at you if the voltage drops dangerously low while driving.
dolucasi is offline
post #20 of 40 (permalink) Old 05-13-2019, 05:18 AM
Date registered: Jul 2010
Vehicle: '85 300D Turbo, '91 420SEL, '92 190E 2.6, '09 C350, '12 E63 Wagon
Quoted: 581 Post(s)
NO START ?
On my old W123, I had a problem develop where I could bump the ignition key and the switch would turn ever so slightly in the off direction. This would result in weird dim warning lights as mentioned. (Something to look at, above ground)...
(Also remembered the alternator didnít seem to be running in this slightly off position as well so thought Iíd mention it)...
jzchen is online now
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Cold Start - Multiple Misfires ~ then clears up 41099ML430 W163 M-Class 32 11-06-2017 11:22 AM
Battery Drain? Slow/Rough Start Issues AndyK150 W212 E-Class 6 02-02-2017 04:37 PM
Hard start cold or hot? Fix and workaround. Chadahar W126 S,SE,SEC,SEL,SD,SDL Class 10 07-30-2011 12:20 PM
Miserable evening, to start off the long holiday weekend Ramesh W126 S,SE,SEC,SEL,SD,SDL Class 27 02-06-2011 05:50 PM
NO START Issue - Intermittent - Help diagnose! :) 96e320 W210 E-Class 7 06-05-2007 10:01 PM
