Squeaky Suspension, Pulling to left and right - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 04-24-2019, 02:27 PM Thread Starter
OBX97's Avatar
Date registered: Apr 2019
Vehicle: 1992 Mercedes 190e 2.0
Quoted: 2 Post(s)
My 1992 2.0 190e is squeaking when going over bumps. Suspension components look ok, but not sure what it is. Please see attached photos for (hopefully) what will help solve this issue! Steering at high speeds sometimes wants to pull after going over a bump. Uploading a video to share in a follow-on.
ID:	2507398   Click image for larger version
OBX97 is offline
post #2 of 7 (permalink) Old 04-24-2019, 02:29 PM Thread Starter
OBX97's Avatar
Quoted: 2 Post(s)
Please see this YouTube video I filmed this afternoon, this is the squeaking.
https://youtu.be/AAM5k6BkiII
OBX97 is offline
post #3 of 7 (permalink) Old 04-25-2019, 11:39 PM
Date registered: Dec 2012
Vehicle: 89 190E2.6- 5-speed Manual, 95 E320 Sportsline-sold, 2001 E320 4matic Wagon-sold
Quoted: 543 Post(s)
Send a message via Skype™ to dolucasi
It sounds like two metal parts that are rusted are scraping against each other. Almost like the spring touching the body on top.
You could undo the strut on top and do the bounce test to eliminate that. And if that does not do it, you could undo the anti roll bar and do the bounce test that.
But I would suspect the spring hitting the body or some sort of control arm bushings gone bad.
It does look quite a bit rusty down there.
dolucasi is offline
post #4 of 7 (permalink) Old 05-01-2019, 05:55 AM Thread Starter
OBX97's Avatar
Quoted: 2 Post(s)
Thank you! I'll check that out and report back
dolucasi likes this.
OBX97 is offline
post #5 of 7 (permalink) Old 05-01-2019, 06:25 PM
lomtevas's Avatar
Date registered: Nov 2006
Vehicle: 1986 190E 2.3-16, 1992 190E 2.3, 2014 CLA250 and 2015 GL350 BTC
Quoted: 63 Post(s)
Send a message via Skype™ to lomtevas
Your rear suspension multi-link bushings have likely failed. Replace your multi-links.
The home of the two 201's.
lomtevas is offline
post #6 of 7 (permalink) Old 05-01-2019, 08:57 PM
Date registered: Mar 2004
Vehicle: Amethyst 2001 C320
Quoted: 5 Post(s)
Steering pulling after hitting a bump could be tie rods, ball joints, or bushings on the front control arms.
Black Swan likes this.
n0alpha is offline
post #7 of 7 (permalink) Old 05-01-2019, 11:07 PM
Black Swan's Avatar
Date registered: Sep 2015
Vehicle: 2010 E3504matic , 1998 E320
Quoted: 15 Post(s)
Steering at high speeds SOMETIMES wants to pull after going over a bump. Uploading a video to share in a follow-on.
Don't assume the sounds and the pulling are not more than 1 issue. Diagnosing is typically a process of elimination when the solution isn't obvious. If you're not familiar with suspensions you could be installing parts without resolving your concerns.
Bushings can make suspension symptoms "sometimes" happen. You can use a pry bar or large channel lock pliers to apply pressure on many joints that have bushings, movement is an issue.
I watched your video and the squeak sounds more like an old shock that has lost it's oil. If that's the case, a squirt of WD40 on the shaft would confirm or deny.
Good luck and let us know how you make out with it.
Dave Kost likes this.
Black Swan is offline
