M102 Engine Cylinder head compatibility - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-17-2019, 01:51 AM Thread Starter
Date registered: Apr 2019
Hi all
Just signed up to these forums, having been a lurker for some time.
I have a W123 Coupe which has an M102.985 engine (2.3 out of a late 80`s 190) instead of the original M102.980. Now the M102.985 has a blown head gasket due to overheating - I suspect the head is warped, possibly beyond what a resurfacer can salvage.
I also have a M102.962 (2.0 out of a late 80`s 190) which is a good engine, but I don`t want to lose 300cc worth of screaming performance (!) and was hoping I could use the 962 head on the 985 block to create one good 2.3 engine.
I have the engine service manuals for the M102.985, which states:
"Cylinder head
The same cylinder head is installed on engines 102.9221924 as on engines
102.962/982/985. Only one cylinder head version is supplied as a replacement part. This cylinder head must not be installed on the previous engine 102.961. "
This suggests that I can use the 962 head on the 985 engine, but as far as I know the bores are different, which makes me suspicious as to whether this is true.
Does anyone know definitively if this is / isn`t possible.
Thanks in advance.
James
jamescross1973 is offline
post #2 of 3 (permalink) Old 04-17-2019, 06:31 PM
Date registered: Dec 2012
Vehicle: 89 190E2.6- 5-speed Manual, 95 E320 Sportsline-sold, 2001 E320 4matic Wagon-sold
Quoted: 543 Post(s)
Send a message via Skype™ to dolucasi
If the bores are different, I do not see how the heads would be compatible. Even with the same bores for example a 1990 2.6 will not fit a 1989 2.6 (both M103's) because of the piston shape and the matching valve chamber shape. Been there, done that.
Unfortunately, I have no knowledge of M102 engines.
dolucasi is offline
post #3 of 3 (permalink) Old 05-01-2019, 07:11 AM
Dr. Sternschnuppe's Avatar
Date registered: Dec 2011
Vehicle: 600 (3.200 mm)
Quoted: 150 Post(s)
Exclamation
Cylinder head from 2.0 is not suitable for 2.3.
Dr. Sternschnuppe is offline
List of Fault Codes....(DTC) sgtpepperaut W163 M-Class 17 06-24-2019 03:17 PM
W220 S430, S500 And S55 Engine removal W/O 4MATIC SChalmers W220 S-Class 50 08-17-2018 07:39 AM
We Need A Permanent Sticky for Error Codes Hary Gahtoe C208/A208 CLK-Class 22 01-22-2010 12:11 PM
320 CDI v6 or straight six? gartracescort W211 E-Class 14 09-17-2007 01:20 PM
ML NOT STARTING IN HOT WEATHER OR HOT ENGINE!!!!! jmarenas W163 M-Class 11 09-06-2005 03:42 PM
