Aux fan and clutch fan - Mercedes-Benz Forum
post #1 of 30 (permalink) Old 05-20-2013, 06:51 PM Thread Starter
Vehicle: 1991 190E 2.3
Is the clutch fan actuated by the 100 degree fan switch on the engine? Im trying to test the clutch fan and am only getting response from the aux fan.
Sent from my DROID BIONIC using AutoGuide.Com Free App
Darryl Elkins is offline
post #2 of 30 (permalink) Old 05-20-2013, 09:30 PM
Nfsjunkie91's Avatar
Date registered: Aug 2010
Vehicle: '87 190E 2.3 Manual, '81 500SEL 4whl SLS, '91 300SEL
Quoted: 5 Post(s)
It is on my '87 2.3. At 100C clutch fan and low speed e-fans come on, at 110C clutch fan and high speed e-fans come on.
--- Mercedes Timing Chain Crimper (Single/Double Row) Tool for Rent. PM me for details. ---
Nfsjunkie91 is offline
post #3 of 30 (permalink) Old 05-21-2013, 05:07 AM Thread Starter
There has to be a second switch if there is something happening at 100 and something else happening at 110. The switch that I was checking is either on or off there isn't a second setting. Where is the other switch?
post #4 of 30 (permalink) Old 05-21-2013, 04:01 PM
Date registered: Aug 2012
Vehicle: 1991 190e 2.3
Quoted: 8 Post(s)
I don't know if you have a 2.3 or a 2.6.
On my 91 2.3 there are 3 temp sensors on the top front. One goes to the CIS, another to the electric fan, and the last to the mechanical fan. I don't remember which is which but it should be easy enough to trace the wires.
Anomaly is offline
post #5 of 30 (permalink) Old 05-21-2013, 04:04 PM
holmesuser01's Avatar
Date registered: Jul 2009
Vehicle: 1984 190E 2.3 engine Automatic, 2002 C240 2.6 Automatic
My '84 has a sensor switch on the water pump cover that activates the electric fan.
There is another one up near the oil fill hole that controls the fan clutch. When I got it, my car was wired to run the clutch fan all the time, and it got really loud on the highway.
On my car, the sensor to the right with the red color on it controls the fan clutch. The newer versions of our cars are similar, but the temperature switch might be different.
holmesuser01 is offline
post #6 of 30 (permalink) Old 05-21-2013, 05:09 PM
Quoted: 5 Post(s)
My vehicle has 1 switch with 3 connections, one 2-pole and one 1-pole. It looks like this: http://www.autohausaz.com/secure/Par...0065454224.jpg
There are several temperature sensors that serve other purposes, but that's the fan switch on mine.
post #7 of 30 (permalink) Old 05-21-2013, 09:25 PM
Turnpike's Avatar
Date registered: Mar 2008
Vehicle: '87--190E 2.3-16v(being rebuilt), '99--C230 Kompressor
Quoted: 11 Post(s)
same temp switch as the 16v
i need my star cleaned too
'99 C230 Kompressor
Turnpike is offline
post #8 of 30 (permalink) Old 05-25-2013, 02:15 PM Thread Starter
Here is a pic of what I am working with but from a different angle. However I just realized the photo is up side down.
post #9 of 30 (permalink) Old 05-29-2013, 08:27 PM Thread Starter
The third sensor and connector do not look like the others posted here. Is the connector with the larger black connector the one? If so how does the cable come off? I hope to make sure the clutch fan works before I take on a 7000 mile trip.
post #10 of 30 (permalink) Old 05-29-2013, 08:41 PM
The third one in your case is the computer control. Leave it alone.
