a few questions on brakes and strut squeak - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-28-2012, 04:00 PM Thread Starter
Date registered: Mar 2011
Vehicle: 1986 2.3 A/T 102.985 vin DA28D5HF284301
i have replaced front rotors and pads but after a couple of weeks front pads start to squeal even at low temperature (or just coming out from garage). went back to the shop and they were happy to exchange the squeaking pads. It eventaully ended up to these brands (meyle, trucktec, icer) that were on and off my car but the squeaking still persists todate. I went to another MB shop and was asking for the OEM and they handed out "textar" but shop owner claims that even with the textar there will still be squeaking. Is there an end solution to this? Please note that not all brands in US are available here, so I will just need pointers to confirm that textar do squeak.
second, I changed rear struts with bilstein HD, after a few runs, the right rear strut started squeaking but problem is that I am unable to confrim were this is coming from. The only suspect I have is the rear strut since this was the last item touched in the process. What else could I be missing?
Thanks in advance!
tab688 is offline
post #2 of 3 (permalink) Old 02-28-2012, 04:13 PM
1984babybenz's Avatar
Date registered: Nov 2009
Vehicle: 1984 190D 2.2
Have you tried disk brake quiet on the back of the pads?
Also did you lubricate the piston seal on the caliper?
1979 Pontiac Firebird 5.7- 86,142 miles
1981 Chevrolet Corvette 5.7
1984 Mercedes 190D 2.2 Auto - 140,628 miles
1987 Chevrolet Sprint 1.0 - 139,000 miles
1989 Oldsmobile Cutlass Calais S - 123,000 miles
1989 Chrysler New Yorker - 95,000 miles
1991 Dodge Stealth R/T - 101,000 miles
1999 Dodge Durango - 178,000 miles
2003 Dodge Dakota - 203,000 miles
1984babybenz is offline
post #3 of 3 (permalink) Old 03-01-2012, 03:40 PM Thread Starter
Haven't tried it. Will check it local shops has it on stock. Thanks!
tab688 is offline
brakes that squeak after being replaced spencer91387 W211 E-Class 15 06-16-2016 07:20 AM
BRAKES SQUEAK HELP! kgomez1992 C208/A208 CLK-Class 11 12-06-2011 08:38 AM
New brakes, New discs, Still Squeak! laura75 W220 S-Class 5 12-01-2010 09:13 PM
Anyone else have a bad rear strut?squeak-squeak 4benzes W163 M-Class 25 11-26-2010 04:13 AM
Brakes Squeak When Backing up? texexec W126 S,SE,SEC,SEL,SD,SDL Class 7 10-14-2003 10:39 PM
