Gaz ans clutch pedal adjustments - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-09-2009, 08:33 AM Thread Starter
Ivan820's Avatar
Date registered: Jan 2008
Vehicle: 1985 500SEC
Hello to you all,
i was hoping any of you could help me out with a little question.
1: My gaz pedal has about a whole inch of loose play at the very top before anything happens when depressing it. I got in a BMW last night (E30) and the gaz pedal in that one had absolutely no loose play. RPM's go up as soon as you make contact with the pedal. This leads me to beleive that the 190 should also be like that. Could any of you give me instructions on how to "tighten" the gaz pedal in order to elimiate any loose play at the very top? (hopefully you understand what i mean by "loose play")
2: And secondly, I've noticed that the friction point on the clutch is quite high. Its at about 85% of the pedal. Is there any way to lower the friction point to about 65-70% of the clutch pedal?? Can someone give me instructions on how to "thighten" or "loosen" the clutch cable a bit? Many thanks. And hopefully you guys understand this question too.
Many thanks, looking forward to your replies.
Ivan
Edit post:
Furthermore, while cleaning up the inside of the car not long ago, i found this little device in back of the gaz pedal. It was a sort of premature gaz pedal stoper, my car being a 1.8 i said i'll have none of that (need as much power as i can get) so i removed it. The only difference i've seen is your able to push the pedal a little deeper, an unbeleivably minimal power gain. Was that a wise action on my part? Is the little stoper really that important to the cars operation?
Ivan820 is offline
post #2 of 2 (permalink) Old 10-09-2009, 09:40 AM
Premium Member
ducatipaso's Avatar
Date registered: Jul 2006
Premium Member
Send a message via AIM to ducatipaso
you may be stretching the cable, I'd replace the stopper on the floor.
there is a free-play adjustment at the top of the pedal, it's a white plastic threaded collar, an absolute sob to get at.
keep in mind, however, that the free play you experience may not be related to the cable, but to wear on the bellcrank on the CIS. my car has this problem... and if you dial out all the cable's slack, your throttle will not return to zero and therefore will not activate the ICV and your idle will be improper.
the throttle feeling on these cars is quite different to an E30... I have one of each.
ducatipaso is offline
CLUTCH PEDAL SWITCH sprintervm W901-906 Sprinter 1 02-25-2009 12:01 PM
W116 Clutch Pedal coastline W116 S, SE, SEL, SD Class 8 01-21-2009 07:39 AM
Clutch pedal assy. deezer5150 R/C107 SL/SLC Class 1 10-30-2007 07:06 AM
Clutch Pedal Adustment??? Metastable W203 C-Class 3 11-17-2004 09:12 PM
Clutch Pedal ShaneO G-Class 1 11-25-2002 12:30 PM
