fan clutch question - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 09-09-2009, 08:25 AM Thread Starter
tnez190e's Avatar
Date registered: Dec 2008
Vehicle: 1988 190e 2.3 8v 5spd- manual
Send a message via AIM to tnez190e
Question fan clutch question
Ok so I'm trying to fix my fan, I purchase a fan clutch but its a metal piece that I don't know where it goes, should I exchange it for just a fan assembly?
How does the fan clutch look like anyways?
Thanks in advance
tnez190e is offline
post #2 of 12 (permalink) Old 09-09-2009, 08:33 AM
Kynyption's Avatar
Date registered: Jan 2006
Vehicle: 1985 w201 Euro 2.3-16vlv / 1992 w201 2.6 Sportline Manual
Its a big electro magnet.
Kynyption is offline
post #3 of 12 (permalink) Old 09-09-2009, 08:39 AM Thread Starter
tnez190e's Avatar
and that goes where?
because when i took my fan out it has a metal ring like the one i have attached
so would i have to change the pulley or just the fan blade?
tnez190e is offline
post #4 of 12 (permalink) Old 09-09-2009, 12:27 PM
Kynyption's Avatar
The clutch is behind the pulley chief.
The fan blade has a metal ring so when the magnet turns on....the metal ring gets pulled stuck to the pulley/magnet behind it. Get it?
post #5 of 12 (permalink) Old 09-09-2009, 08:12 PM Thread Starter
tnez190e's Avatar
i get it.... thanks for the response
make me feel more dumb
does the fan need to be running at engine speed? at all times? or does it engage at certain speed?
tnez190e is offline
post #6 of 12 (permalink) Old 09-09-2009, 09:50 PM
Kynyption's Avatar
Haha no need to feel dumb.
Its a temp that turns the fan on not engine speed.
post #7 of 12 (permalink) Old 09-10-2009, 06:53 AM
eameno's Avatar
Date registered: May 2008
Vehicle: 1992 190E 2.3 aut. white Benz
hi,
How did you understand the problem is in the clutch? My car's fan also doesn't work for a while...
and a dumb question: how much is this fan important for the engine? what happenes if I drive with notworking fan?
Thanks
eameno is offline
post #8 of 12 (permalink) Old 09-10-2009, 06:56 AM
DP
DP's Avatar
Vehicle: 190E, SLK350
Quoted: 2101 Post(s)
If the fan fails then your aux fan/fans should take over after you reach a higher temp. If those fail then you will overheat the car and will end up needing a head job to replaced the warped head.
DP is offline
post #9 of 12 (permalink) Old 09-10-2009, 10:17 AM
Kynyption's Avatar
I run no engine fan but i have electric fans.
To test your fan you can provide power to the magnet and see if it engages.
post #10 of 12 (permalink) Old 09-10-2009, 06:50 PM Thread Starter
tnez190e's Avatar
ok... so it wasn't the clutch, its the temp switch thats bad as I took the connector off and jumped the connector to the fan which works... so my question is
does the engine fan need to be running at engine speed in idle?
right now i left the cable connected to the switch which has the fan on at all times, is this good or bad?
tnez190e is offline
Fan Clutch Question KarenV W201 190-Class 53 01-20-2007 03:40 AM
Question on fan clutch MBeige W123 E,CE,D,CD,TD,TE Class 4 05-28-2006 01:11 AM
Fan clutch Question Jayare W124 E,CE,D,TD Class 3 03-14-2006 05:33 PM
fan clutch question ehizon W140 S-Class 7 02-27-2006 09:42 AM
fan clutch question Ted G-Class 5 10-08-2001 07:56 AM
