Vacum lock system question ??? - Mercedes-Benz Forum
post #1 of 17 (permalink) Old 02-15-2008, 07:06 PM Thread Starter
Date registered: Oct 2004
I tried to hook up an Keyless entry which should be connected to the vacum pum. The keyless entry did not work. so, I change my mind
I rewired everything back the way it was before
Then
The vacum do not activate when I try to open from the driver or passenger door however the pump activate from the trunk
Any idea what did I do wrong ??
could be any fuse ???
could be any relay that i can not find hidding some where because i check all of the fuses and they are ok ??
Please help
MBUSER is offline
post #2 of 17 (permalink) Old 02-15-2008, 07:46 PM
IR MODERATOR
Jippi's Avatar
Vehicle: 1996 Volvo 855GLT, 1993 MB 190e 2.3 8v, 1998 Subaru Outback SUS, 1991 BMW 525, 1998 MB C230
Quoted: 5 Post(s)
Send a message via AIM to Jippi Send a message via MSN to Jippi
what did u cut when u did the locks?
1993 MB 190E 2.3 105k- its alive..
1996 Volvo 855 GLT-R 350k still rolling
1998 Subaru Outback SUS 210k- Daily Driver 2011 Toyota Camry XLE 36k
1991 BMW 525I stock as stock gets 98k (Wrecked) 1998 MB C230 209k possessed by the devil
Benzworld.org---Tri-State Crew
Jippi is offline
post #3 of 17 (permalink) Old 02-15-2008, 08:27 PM Thread Starter
I cut a blue wire however after see that the keyless did not work I rewire the blue wire back. and that was it
MBUSER is offline
post #4 of 17 (permalink) Old 02-15-2008, 08:37 PM
IR MODERATOR
Jippi's Avatar
Quoted: 5 Post(s)
did you use relays for the keyless or did you hook it straight to the wires? where did you hook them up to as in the drivers door or the passengers door or at the pump? check all of your connections again.
Jippi is offline
post #5 of 17 (permalink) Old 02-16-2008, 04:35 PM Thread Starter
I connected at the pump using a relay.
I removed the stupid Keyless entry totally and I rewired back the way it was before.
I check the fuse and the fuse is fine
The pump works and all doors open when I use the car key at the trunk.
Question: why the driver and passenger no longer activate the pump???
What is in between the (driver , passenger) and the vacum pump??
Is there a fuse in between ???
Is there electrical device that by mistake I shorted it up ????
Why by the trunk still working and not by the driver or passenger doors???
Please someone help me to solve this mistery>>>>>>
MBUSER is offline
post #6 of 17 (permalink) Old 02-16-2008, 05:46 PM
HATTENATOR's Avatar
Date registered: Jan 2008
Vehicle: 1988 190E 2.3
I attached these to try to give you an idea of how the system is setup. It really depends on what year of vehicle you have because there was changes over the years.
You might try disconnecting the plug going to the pump and then disconnecting the battery and leaving it over night and let the system reset. Then hook it back up.
I have the full testing procedures for the system if you want them or you can get a copy of the w201 manual here Modified Technologies, Inc | Enthusiast Gear which has them in it
HATTENATOR is offline
post #7 of 17 (permalink) Old 02-16-2008, 08:07 PM
IR MODERATOR
Jippi's Avatar
Quoted: 5 Post(s)
it sounds like you shorted the pump. im gonna do a writeup on keyless install when i figure out what car im gonna use, more then likely its the 93 which is a clean slate. im gonna move the mods over from the 87 and keyless is one of them. unless someone in jersey has a mb that needs keyless im willing to install it and do a write up on it.
Jippi is offline
post #8 of 17 (permalink) Old 02-16-2008, 09:38 PM
Date registered: Sep 2007
I'll post a schematic diagram later, after the hocky game..
The keyless entry module has to be able to output a pulse of at lease 2.5 seconds for it to work properly.
cypress188 is offline
post #9 of 17 (permalink) Old 02-16-2008, 09:38 PM Thread Starter
The pump works when i open the trunk
MBUSER is offline
post #10 of 17 (permalink) Old 02-16-2008, 10:08 PM
IR MODERATOR
Jippi's Avatar
Quoted: 5 Post(s)
the pump has an internal circuit board. just because the pump works doesnt mean its working properly. where did you cut the wire to tap into the locks? theres several locations under the drivers floor area, the pass. floor area, the trunk, or from the pump. the pump has a spade disconnect that is near the pump thats a good place to tap into that doesnt require actual cutting. jump the brown black and green in the drivers door lock or the brown and blue in the pass side that goes into the switch/actuator. if theres movement then the switch is bad. if theres nothing then your pump is bad. jumping the wires acts like you are manually switching it.
Jippi is offline
Vacum Door Lock System. gmnidrm R170 SLK-Class 3 03-04-2007 11:45 AM
Vacum System Alfredo W126 S,SE,SEC,SEL,SD,SDL Class 0 03-28-2005 07:55 AM
Trunk Lock System W124-E420-V8 W124 E,CE,D,TD Class 0 02-27-2005 09:19 PM
lock door system ----need help bluecgar99 R170 SLK-Class 6 06-07-2004 01:52 PM
Diffrential lock system Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 1 11-06-2001 01:22 AM
